Audio Not working Hudiy
sparrohwk
Re: Audio Not working Hudiy
Post by sparrohwk »
So here's the thing.... on boot and connection of the phone (VIA USB) nothing happens. The SINK is defaulting to hudiy_equalizer_sink, but if I switch to bluez_**** nothing happens, wait 3 seconds, switch back to hudiy_equal****** nothing happens....again wait 3 seconds and switch back to bluez, and boom, playback happens. Additionally SINK #'s change randomly.....but fix (listed above with the variable sink #) works every time
88 bluez_output.BLUETOOTHMACADDRESS PipeWire s16le 2ch 48000Hz SUSPENDED
97 hudiy_equalizer_sink PipeWire float32le 2ch 48000Hz SUSPENDED
112 echo_cancel_sink PipeWire float32le 2ch 48000Hz SUSPENDED
keith@MGMedia:~ $ pactl set-default-sink 88
keith@MGMedia:~ $ pactl set-default-sink 97
Step 1 - Plug in phone and HUDIY recognizes it and starts playing (no sound through head unit) On connection, HUDIY defaults to "hudiy_equalizer_sink"
Step 2 - I set default sink to bluez_output.MACADDRESS (nothing happens)
Step 3 - I set default sink to hudiy_equalizer sink (nothing happens)
Step 4 - I set default sink to bluez_output.MACADDRESS (music starts playing immediately)
sparrohwk
Post by sparrohwk »
Any additional thoughts on what could be causing this behavior?
You can check the solution from this thread viewtopic.php?t=257. It might be related to the echo-cancel module.
sparrohwk
Post by sparrohwk »
Thank you but if I replace the contents of the startup.sh file, it seems like the hudiy software is hanging on the splash screen. Raspbian Trixie boots no problem but when hudiy tries to load, just fluctuating HUDIY flash screen
sparrohwk
Post by sparrohwk »
So I found that if I just simply comment out (#) the Echo-cancel sink in the startup.sh file, it works immediately. I'm finding there is a slight delay (caching?) between the screen and the audio. If I hit next or previous, the tune will continue to play about 2-3 more seconds before reacting to the command. Same if I slide the bar to a different section of the song.
Thanks for all your help in working my way slowly through these growing pains :)
