My Build Seat Leon 5F
156asd156
Post by 156asd156 »
First of all, huge thanks to the Hudiy team for this amazing project!
I installed it on my Seat Leon 5F. As you can see in the picture, I used 3D printed parts to mount the screen.
The Raspberry Pi and everything else were placed inside the glove box.
WhatsApp Görsel 2025-09-21 saat 16.57.57_138f3047.jpg (235.71 KiB) Viewed 822 times
WhatsApp Görsel 2025-09-21 saat 16.57.57_913dd6b7.jpg (188.25 KiB) Viewed 822 times
Re: My Build Seat Leon 5F
You’re very welcome! Great to see you were able to use Hudiy in your project — it looks fantastic. Very clean setup.
156asd156
Post by 156asd156 »
**Hudiy Project Update – Steering Wheel Controls and Vehicle Status Widget**
Hi everyone,
I wanted to share a new update on my Hudiy project.
The factory steering wheel buttons are now decoded from the CAN bus and mapped to Hudiy API commands. This means I can control the interface directly from the original steering wheel buttons without using any external controller.
**Vehicle Status Widget**
I also added a custom car status widget to the Hudiy dashboard.
This widget shows real-time vehicle information decoded from CAN, including door states. The car graphic updates depending on which door is open or closed. For now, I have confirmed the CAN data for the four doors and mapped them into the widget.
The widget is designed to be expanded further with more vehicle data such as speed, RPM, outside temperature, coolant temperature, oil temperature, fuel consumption and other useful information.
Another improvement is automatic brightness and theme control. The system now reads the brightness information from the vehicle’s instrument cluster over CAN. Based on this value, Hudiy can automatically adjust the screen brightness and switch between dark and light mode, similar to the original vehicle behavior.
Since the beginning of the project, I have also worked on:
* Hudiy API communication
* Steering wheel button decoding
* Dashboard layout customization
* Automatic brightness control from the instrument cluster
* Automatic dark/light mode switching based on vehicle brightness data
* Vehicle status widget
* Door state decoding from CAN
* Outside Temp from CAN
* Clock/Date info from CAN
The next steps will be improving the visual design, making the vehicle status screen more polished, adding smoother brightness/dimming behavior, and decoding more CAN signals.
I’m still actively developing and testing the system, but it is already becoming much more usable and integrated with the car.
https://www.youtube.com/shorts/NfhEbyzc ... ture=share
