Create Separate Front Back and Subwoofer
EnDy500
Post by EnDy500 »
Everything seems to be working audio wise but I don't know how to create a fader or separate front, rear, and subwoofer adjustments.
Re: Create Separate Front Back and Subwoofer
The controls for fade/balance and subwoofer will appear automatically in Hudiy if the audio sink configured in volumeSinkName (https://github.com/wiboma/hudiy/blob/ma ... n.md#sound) has Front Left, Front Right, Rear Left, Rear Right, and LFE channels (https://github.com/wiboma/hudiy/tree/main#audio).
What sound card are you using in your setup? For 4.1 support, we recommend the CM6206 card. The thread with the configuration for this card can be found on the forum: viewtopic.php?p=889#p889
EnDy500
Post by EnDy500 »
Thank you for the reply, I must of missed the last step the last time I went through it. I just followed the instructions you provided for the CM6206 car and it's working. Thank you very much.
