Equalizer
We optimized the DSP equalizer algorithms to reduce CPU usage. We also added Bass and Treble boost effects, allowing you to fine-tune high and low frequencies independently. While similar to the "Loudness" effect, this feature offers more granular control, letting you adjust both the frequency threshold and the gain.
The bass and treble boost effects can also be controlled via the API.
Updated equalizer presets for the new algorithms can be found on our GitHub: https://github.com/wiboma/hudiy/blob/ma ... .json#L146
Bluetooth
We have improved the connection process between the phone and Hudiy. The HFP profile now connects in a more reliable way, especially during initial pairing.
Dummy profiles
We added the ability to register dummy HFP and A2DP profiles directly from Hudiy. This should simplify the setup when Android Auto audio is routed through another Bluetooth device (e.g., a factory head unit), while Hudiy handles the Android Auto projection. When these features are enabled, profile registration by OS components (e.g., PipeWire) should be disabled to prevent conflicts.
Direct renderer
We have adapted the direct renderer for the recently released 6.18 kernel on Raspberry Pi.
Other improvements
- Ability to position and size overlays relatively to the Hudiy window.
- Ability to overwrite colors in both dark and light themes.
- Ability to enable/disable caching HTML/JS content loaded by the WebView (widgets, overlays, applications).
- New API message to track the last visible action.
