RNS-E in Audi A2
Re: RNS-E in Audi A2
Are you using TV Mode to display the image? If so the pins on the 32pin connector for AUX-in need to be moved for the audio in on the TV mode instead of AUX mode
I moved the pins on the 32 connector to 13 28 and 29 and that sorted it
06, 21, 22 are for AUX-IN. 13, 28, 29 are for TV Mode.
Sorry, didn't see there was a second page. I have the audio going directly to the line out pins on the quadlock connector. I don't believe I have the 32-pin connector anymore.
I have the 3.5mm wires going to C3, C5, C8, C9, and C11 on the EXT Control Connector
I don't have the 32-pin connector anymore as I ripped out all the RNS-E internals. I'm running a Pi with a CarPiHat Pro DAC, with the 3.5mm output wired directly to the line out pins on connector C (pins 3, 5, 8, 9, and 11) on the quadlock. I'm trying to feed audio from the Pi directly into the car's amp via those pins if it's possible
