Welle.io DAB+ Radio
Marcel7162
Welle.io DAB+ Radio
Post by Marcel7162 »
I wonder if its posible to get DAB+ running on Hudiy? For example via Welle.io.
Re: Welle.io DAB+ Radio
Hudiy is essentially a regular windowed application, just like Welle.io. On Raspberry Pi OS you can run any applications in parallel. If Welle.io has an HTML/JavaScript interface, you can display it in Hudiy using WebView https://github.com/wiboma/hudiy/blob/ma ... d#web-view.
The remaining question is whether the RTL-SDR dongle will be able to handle two applications simultaneously (Hudiy with FM radio and Welle.io).
Hiphouser
Post by Hiphouser »
I'm testing 2 good app's under android phone:
DAB-z and DABdream, but only for android phones, i have heard about "Waydroid" to emulate android app's... It's may be an idea!
I hope it can be possible to install some app's for Trixie's OS like
Welle.io or AbracaDABra
Hiphouser
Post by Hiphouser »
After some web search, I think I'll use "DABlin", Trixe compatible
D3dl3g
Post by D3dl3g »
Hiphouser wrote: Thu Feb 19, 2026 10:46 am After some web search, I think I'll use "DABlin", Trixe compatible
Did you have any joy intergrating into Hudiy?
@Hudiy, how is the FM Radio screen displayed? is ti web page or had baked into the app?
im interested to try to get a simlilar look as i try to implement welle-io into my copy of hudiy if its hard baked are you able to share the location of the image files used for the play controls etc etc?
The FM radio screen is built in Hudiy. All the icons used by Hudiy are located in the font files in $HOME/.hudiy/share/assets/fonts (MaterialSymbolsRounded.ttf, HudiySymbols.ttf).
List of glyphs in Material Symbols is available at https://fonts.google.com/icons
Glyphs from Material Symbols used on FM radio screen:
  • heart_check
  • heart_plus
  • grading
  • fast_rewind
  • chevron_left
  • play_arrow
  • pause
  • skip_previous
  • skip_next
  • chevron_right
  • fast_forward
https://github.com/wiboma/hudiy#icons
