Welle.io DAB+ Radio
Marcel7162
Welle.io DAB+ Radio
Post by Marcel7162 »
I wonder if its posible to get DAB+ running on Hudiy? For example via Welle.io.
Re: Welle.io DAB+ Radio
Hudiy is essentially a regular windowed application, just like Welle.io. On Raspberry Pi OS you can run any applications in parallel. If Welle.io has an HTML/JavaScript interface, you can display it in Hudiy using WebView https://github.com/wiboma/hudiy/blob/ma ... d#web-view.
The remaining question is whether the RTL-SDR dongle will be able to handle two applications simultaneously (Hudiy with FM radio and Welle.io).
Hiphouser
Post by Hiphouser »
I'm testing 2 good app's under android phone:
DAB-z and DABdream, but only for android phones, i have heard about "Waydroid" to emulate android app's... It's may be an idea!
I hope it can be possible to install some app's for Trixie's OS like
Welle.io or AbracaDABra
Hiphouser
Post by Hiphouser »
After some web search, I think I'll use "DABlin", Trixe compatible
