It is still in research phase. We don't have a defined date for a potential release yet.
Radio
Re: Radio
EN: Hello, I have a radio dongle. I am sharing the link below. Will this product work in your application?
LH: Cześć, mam klucz radiowy. Poniżej zamieszczam link. Czy ten produkt będzie działał w Państwa aplikacji?
LİNK: https://tr.aliexpress.com/item/10050070 ... cification
Re: Radio
I'm doing some test with great Nooelec RTL-SDR v5.
It work but need to integrate that in Hudiy.
Re: Radio
DAB+ seems to be doable. at least as an "overlay".
i had a play with RTL-SDR.com V4 and a cheap <£15 antenna. i couldnt get DAB+ AND FM working. this was due to the antenna ONLY being capable of DAB+, even then i had very poor results. a few tests later and im pretty sure i need a better antenna, so at some point this week i will be looking at having another go.
i did notice that with welle.io active, the SDR module couldnt be seen by Hudiy therefore you would loose FM capability.
so if you want DAB+ AND FM then we may have to wait until the wonderful devs manage to implement it.
at the moment you either have to workaround DAB+ with something like welle.io and overlays OR use the inbuilt FM functionality.
