Radio
Re: Radio
Marcel7162 wrote: Tue Nov 18, 2025 12:44 pm Hallo,
is there an Update on DAB+?
It is still in research phase. We don't have a defined date for a potential release yet.
Hiphouser
Re: Radio
Post by Hiphouser »
It will be Nice!
MOTOPLAY
Re: Radio
Post by MOTOPLAY »
EN: Hello, I have a radio dongle. I am sharing the link below. Will this product work in your application?
LH: Cześć, mam klucz radiowy. Poniżej zamieszczam link. Czy ten produkt będzie działał w Państwa aplikacji?
LİNK: https://tr.aliexpress.com/item/10050070 ... cification
lucabor
Re: Radio
Post by lucabor »
Hi, do you have any DAB+ news? We were looking at https://www.welle.io/
Hiphouser
Re: Radio
Post by Hiphouser »
I'm doing some test with great Nooelec RTL-SDR v5.
It work but need to integrate that in Hudiy.
D3dl3g
Re: Radio
Post by D3dl3g »
DAB+ seems to be doable. at least as an "overlay".
i had a play with RTL-SDR.com V4 and a cheap <£15 antenna. i couldnt get DAB+ AND FM working. this was due to the antenna ONLY being capable of DAB+, even then i had very poor results. a few tests later and im pretty sure i need a better antenna, so at some point this week i will be looking at having another go.
i did notice that with welle.io active, the SDR module couldnt be seen by Hudiy therefore you would loose FM capability.
so if you want DAB+ AND FM then we may have to wait until the wonderful devs manage to implement it.
at the moment you either have to workaround DAB+ with something like welle.io and overlays OR use the inbuilt FM functionality.
MathTeacher
Re: Radio
Post by MathTeacher »
MOTOPLAY wrote: Sat Dec 06, 2025 7:52 am EN: Hello, I have a radio dongle. I am sharing the link below. Will this product work in your application?
How is your setup is it able to use this equipment you had mention.|
Can any one suggest how do i connect my Hudiy with FM radio and what model can be suggested to be use .
I an quote new with this system hope can help me
Re: Radio
The FM radio is plug-and-play. Simply plug the RTL-SDR dongle into a USB port, and once the system loads the drivers, it will be automatically detected by the Hudiy radio module. In our test setups, we use RTL-SDR V3 and V4 dongles. Newer versions (V5) may require manual driver installation.
