OBDII Connection Refused
Soup2409
Post by Soup2409 »
Hi, i am trying to get the OBD charts working, have the widgets setup in hudiy dashboard:
And i have managed to successfully pair the OBD reader in bluetoothctl
I have also used the same MAC address in my main_configuration for the obd settings
The logs state multiple times:
[2025-12-23 20:04:16.324259] [0x0000007f11fe1b20] [info]	[hudiy] [ObdDevice] failed to open obd transport.
[2025-12-23 20:04:16.324392] [0x0000007f11fe1b20] [info]	[hudiy] [ObdManager] opening device failed. Retrying...
[2025-12-23 20:04:24.151453] [0x0000007f11fe1b20] [error]	[hudiy] [ObdRfCommTransport] failed to connect, address: 01:23:45:67:89:BA, channel: 1, error: 111, message: Connection refused
Any help would be appreciated
Re: OBDII Connection Refused
which OBD-II dongle model are you using? The MAC address looks a bit unusual.
Quick tip: You can also pair your dongle directly through the Bluetooth menu in Hudiy.
Soup2409
Post by Soup2409 »
One of these generic ones
https://www.amazon.co.za/gp/aw/d/B0DJMH ... asin_title
Heres an actual pic. It didnt come with much documentation either. If the dongle is an issue do you have any suggested products instead 🤔
Also thanks for the tip did not know that 👌
Soup2409
Post by Soup2409 »
I should mention that i did manage to connect to the obd scanner with my phone and retrieve rpm with one of those free apps, so it does work
If you paired via bluetoothctl, try to add the device to trusted list by executing below command in bluetoothctl
trust 01:23:45:67:89:BA
Or you can remove existing pairing and pair with the device using Bluetooth menu in Hudiy. If that will not help, please post output of
sdptool browse 01:23:45:67:89:BA
command (via terminal)
Soup2409
Post by Soup2409 »
I have tried all the above including trusting in ctl as well as removing and then pairing in the hudiy UI
Sdptool returns
The UUID "00001101-0000-1000-8000-00805f9b34fb" visible in one of the previous screenshots is the UUID of SPP (Serial Port Protocol). It should be also visible in sdptool.
Could you please send us full logs from $HOME/.hudiy/log? You can zip the directory and then upload the zip file to this thread.
Please also post output of the
sdptool records 01:23:45:67:89:BA
command.
Soup2409
Post by Soup2409 »
Sorry for the absence
Output of sdptool record
Logs attached but i very very recently switched to a read only system so not sure how this might affect the logs or if it affects the OBD handling?
loggg.7z
(437.97 KiB) Downloaded 20 times
Thanks for the sdptool output. It looks like your dongle listens for RFCOMM traffic on channel 2. By default Hudiy uses channel 1. You can change the channel number in main_configuration.json: https://github.com/wiboma/hudiy/blob/ma ... ion.md#obd (rfcommChannel). Try changing rfcommChannel to 2 and check if Hudiy is able to communicate with your dongle. A restart of Hudiy is required for the change to take effect.
Soup2409
Post by Soup2409 »
That worked, rebooted and it was flawless, thank you so much for the assistance and really efficient troubleshooting
And for hudiy itself lol :mrgreen:
