Customize main_config.json
ltlnmo
Post by ltlnmo »
I wan't to adjust some of the settings for autobox specifically "car icon name". if its saved and restarted all the settings go back to default. is this normal. is this even possible to change
Re: Customize main_config.json
Hello, could you please post configuration file after your modifications?
If the configuration resets to default values, it's most likely a JSON syntax issue. Hudiy can't parse the file correctly and therefore falls back to the default settings.
