SSH wireless setup
Nonspeaker008
SSH wireless setup
Post by Nonspeaker008 »
I’d like to set up SSH access to my Raspberry Pi wirelessly.
I have a TP-Link T2U Nano Wi-Fi dongle available.
The Pi will be mounted in my car, and I want to be able to connect to it for troubleshooting.
Ideally, I’d also like to connect it to a hotspot from my phone when needed.
What’s the best way to configure this setup? :geek:
Re: SSH wireless setup
If you want to use two Wi-Fi adapters, you can specify in the Hudiy configuration which one should be used for the hotspot. You can do this by providing its MAC address in hardwareAddress (https://github.com/wiboma/hudiy/blob/ma ... md#hotspot). Hudiy will then use that adapter to create the hotspot and connect to Android Auto. The second adapter can be used to connect to your regular Wi-Fi network.
We tried running the built-in Raspberry Pi adapter in dual mode (client + AP), but this causes a crash in the Raspberry Pi firmware. Therefore, the only option is to use two adapters.
