Update to version 1.14 (Bookworm) and 2.10 (Trixie) is already available
Posted: Thu Feb 26, 2026 5:40 pm
We are happy to announce that Hudiy 1.14/2.10 is now available. You can find the release highlights below:
FM Radio
We have improved the frequency tuning for the RTL-SDR dongle. As a result, the received signal quality should be better (especially for weaker signals). We have also added an option to boost the audio volume in main_configuration.json in case the volume difference between the FM radio and other audio streams is noticeable.
UI
We added the ability to rotate the Hudiy window directly in main_configuration.json. This significantly simplifies screen configuration in Console (EGL) mode.
Re: Update to version 1.14 (Bookworm) and 2.10 (Trixie) is already available
Posted: Fri Feb 27, 2026 1:56 pm
Will it rotate the Carplay and Android Auto also?
Posted: Fri Feb 27, 2026 3:56 pm
wkl3968 wrote: Fri Feb 27, 2026 1:56 pm Will it rotate the Carplay and Android Auto also?
Yes, it will rotate the whole window and its contents.
Posted: Sat Mar 21, 2026 11:19 am
I'm so looking forward for the next update.
