Update to version 1.14 (Bookworm) and 2.10 (Trixie) is already available
We are happy to announce that Hudiy 1.14/2.10 is now available. You can find the release highlights below:
FM Radio
We have improved the frequency tuning for the RTL-SDR dongle. As a result, the received signal quality should be better (especially for weaker signals). We have also added an option to boost the audio volume in main_configuration.json in case the volume difference between the FM radio and other audio streams is noticeable.
UI
We added the ability to rotate the Hudiy window directly in main_configuration.json. This significantly simplifies screen configuration in Console (EGL) mode.
Please note that the updater performs an incremental update (version by version) to avoid the OS corruption during the update process. If you are using an older version of Hudiy, you may need to run the updater multiple times. You can check your current version in Menu -> Hudiy -> Settings -> About.
Re: Update to version 1.14 (Bookworm) and 2.10 (Trixie) is already available
Will it rotate the Carplay and Android Auto also?
wkl3968 wrote: Fri Feb 27, 2026 1:56 pm Will it rotate the Carplay and Android Auto also?
Yes, it will rotate the whole window and its contents.
I'm so looking forward for the next update.
