Keyboard map
Hiphouser
Keyboard map
Post by Hiphouser »
Hello, where can I check the keyboard mapping in Hudiy folders?
Re: Keyboard map
Hello, If you mean supported key bindings, the list with the description is available on our GitHub:
https://github.com/wiboma/hudiy?tab=rea ... #interface
You can also use the API to inject key events directly to the Hudiy:
https://github.com/wiboma/hudiy/blob/ma ... proto#L626
https://github.com/wiboma/hudiy/blob/ma ... Strokes.py
Hiphouser
Re: Keyboard map
Post by Hiphouser »
Perfect!
But one thing very stange,
I can move up, down, left and right with the keybord narrows in the gemeral menu.
But when I try to navigate in the task bar, nothing working
Re: Keyboard map
To scroll through the elements inside the input scope, press the '1' (scroll left) and '2' (scroll right) keys.
Hiphouser
Re: Keyboard map
Post by Hiphouser »
Yes it'working.
Thanx
