CarPlay Carlinkit Dongle
lovechoco
Post by lovechoco »
Dear everyone,
Firstly, I haven't been able to test the project yet, but congratulations, it looks very promising.
I have a question about the CarPlay dongle. My intention is to use only a wired connection, not wireless. Based on what I saw on one of the forum pages, only the CPC200-CCPA version is compatible. Is this still the case? If so, is it possible to disable the wireless feature?
Thank you in advance,
Best regards
Re: CarPlay Carlinkit Dongle
Thank you!
We tested Hudiy with CPC200-CCPA and CPC200-Autokit dongles. Both work basically the same (act as a headunit). Other CarlinKit dongles are used to convert factory wired CarPlay to wireless (they work differently than CCPA and Autokit).
In the Hudiy settings, you can disable the automatic CarPlay connection via Wi-Fi and then use only the USB connection.
https://github.com/wiboma/hudiy/blob/ma ... md#autobox (autoWirelessConnection)
lovechoco
Post by lovechoco »
Thanks for the feedback. I was especially considering the CCPW model, which is only wired and seems slightly different from the CCPA model (which allows wired & wireless connection).
Best regards
