can hudiy forward ethernet over its hotspot on rpi5
Posted: Thu Feb 12, 2026 10:52 pm
by 0lexy_the_cutie0
i was wondering if i could forward the Ethernet connection to Hudiys ' hotspot so that my phone has actual internet when connected to it?
Re: can hudiy forward ethernet over its hotspot on rpi5
Posted: Fri Feb 13, 2026 6:06 am
Internet sharing/NAT is managed by Network Manager. By default, Hudiy configures the Hotspot to enable sharing. According to our tests, when a phone connects to the hotspot, internet access is routed via the Ethernet port.
However, this behavior may differ for Android Auto projection. Based on our observations, Android Auto uses Wi-Fi exclusively for projection data transmission, effectively ignoring the internet connection.
Posted: Mon Feb 23, 2026 3:50 am
by plateau
I did it through Bluetooth data tethering and it worked flawlessly.
Tomorrow I will share a script with you to make things easier
