can hudiy forward ethernet over its hotspot on rpi5
0lexy_the_cutie0
Post by 0lexy_the_cutie0 »
i was wondering if i could forward the Ethernet connection to Hudiys ' hotspot so that my phone has actual internet when connected to it?
Re: can hudiy forward ethernet over its hotspot on rpi5
Internet sharing/NAT is managed by Network Manager. By default, Hudiy configures the Hotspot to enable sharing. According to our tests, when a phone connects to the hotspot, internet access is routed via the Ethernet port.
However, this behavior may differ for Android Auto projection. Based on our observations, Android Auto uses Wi-Fi exclusively for projection data transmission, effectively ignoring the internet connection.
plateau
Post by plateau »
I did it through Bluetooth data tethering and it worked flawlessly.
Tomorrow I will share a script with you to make things easier ;)
