Open from Debian
F4u5t
Open from Debian
Post by F4u5t »
Is it possible to open Hudiy from the Gnome desktop? currently i have to restart into Hudiy, but sometime i need to work in Gnome and close it, is there anyway to restart it without restarting?
Re: Open from Debian
You can just copy hudiy.desktop file to .local and it will show in Gnome launcher. Then you can e. g. right click on the icon and pin it to the dash.
https://specifications.freedesktop.org/ ... ry/latest/
cp $HOME/.config/autostart/hudiy.desktop $HOME/.local/share/applications/
ioioio
Post by ioioio »
Hallo how to restart from command line (Trixie) when developing for example a Widget or Overlay ?
ioioio wrote: Wed Jan 07, 2026 9:32 am Hallo how to restart from command line (Trixie) when developing for example a Widget or Overlay ?
To start Hudiy locally, simply run the $HOME/.hudiy/share/hudiy_run.sh script in the terminal.
To run Hudiy via SSH, you must export XDG_RUNTIME_DIR and WAYLAND_DISPLAY before execution.
export XDG_RUNTIME_DIR="/run/user/$(id -u)"
export WAYLAND_DISPLAY=wayland-0
https://github.com/wiboma/hudiy/blob/ma ... .md#splash
