Multi-touch on android auto not working
poissonpasne
Post by poissonpasne »
Hi guys, thanks for Hudiy it's a nice project alternative for the old Openauto pro.
I installed it on my raspberry pi 4 model B with a waveshare screen that support multi-touch.
Problem :
On Android Auto google maps or waze, I can't pinch to zoom. The raspberry receives the multi-touch so the problem is probably on the applicative layer.
Do you have any idea to fix this ?
Re: Multi-touch on android auto not working
By default labwc emulates a mouse using touchscreen input. If that is enabled (enabled by default in labwc on Raspberry Pi), applications will receive mouse events instead of touchscreen events. You can disable this in $HOME/.config/labwc/rc.xml by changing mouseEmulation from yes to no in touch node
mouseEmulation="no"
https://labwc.github.io/labwc-config.5. ... emulation=
Additionally, we recommend updating to version 1.6/2.2, where we have improved multi-touch support for the latest labwc.
https://github.com/wiboma/hudiy?tab=rea ... e#updating
poissonpasne
Nice thanks !
What about for autobox? I thought the new carplay update was allowing multitouch for zooming in etc. I can’t seem to get it to work
alex124.rh wrote: Sun Dec 14, 2025 6:55 pm What about for autobox? I thought the new carplay update was allowing multitouch for zooming in etc. I can’t seem to get it to work
Unfortunately, Carlinkit dongles do not support multi touch.
no worries, i’ll reach out and ask if it’s planned in an update. have you spoke to them about this?
