NOOB question
Beaniepud
NOOB question
Post by Beaniepud »
Hello!
I'm new to all this, recently moving over from OAP, which was much easier to set up
I'm trying to work out, how I can make a way that a 3.3v connection (stepped down from the lights of the car) received into a GPIO pin, could trigger dark mode to switch on and off.
I've created a script that edits the dark theme line in the main config file (which does nothing until hudiy is restarted)
And I've been looking at using the API, but there is no simple, clear documentation on how to set this up, or use it at all for those of us who haven't done things like this before!
I'm also looking for a way to make my waveshare screen dim when this GPIO is triggered too
Any help appreciated
In dumb terms please 😂
Thanks
Re: NOOB question
On Trixie you can just execute following commands to install API dependencies:
sudo apt install python3-protobuf
sudo apt install python3-websocket
then clone the hudiy repository
cd
git clone git@github.com:wiboma/hudiy.git
and just execute the DarkMode.py example:
cd hudiy/examples/api/python/
python3 DarkMode.py
You can then add handling GPIO to the DarkMode.py script.
If you are not familiar with Python, you can use an AI chat (Gemini, ChatGPT or any other) to modify the DarkMode.py example and add GPIO support.
Beaniepud
Re: NOOB question
Post by Beaniepud »
Interesting, thank you
Would there be a way to edit that dark mode script, or, sort of slice it into two pieces
One to turn dark mode on
And one to turn it off
Instead of it being a toggle? As a toggle script wouldn't really work with the GPIO system
Also, do I have to use the API system? Could I not just run that script on its own?
I'm so new to all this and it's been so difficult to get started!
Thank you
