After 2.4 update
k.s.deviate
Re: After 2.4 update
This means the sink "bluez_output.E9_A7_26_03_1E_82.1" is not available and does not appear. The script waits until "bluez_output.E9_A7_26_03_1E_82.1" is available.
k.s.deviate
It shows me it's connected and selected as the output device in the audio drop down.
k.s.deviate
k.s.deviate
Executing hudiy_run.sh opens terminal before trying to open Hudiy the terminal output is virtual const QPalette' Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::SystemPalette
Please verify that the hudiy_startup.sh has exactly the same content as we uploaded earlier, and check if the line endings are correct (dos2unix $HOME/.hudiy/share/hudiy_startup.sh).
It works for us locally so most probably your hudiy_startup.sh is somehow corrupted.
