After 2.4 update
k.s.deviate
Re: After 2.4 update
Post by k.s.deviate »
Weirdly, Hudiy won't start now.
This means the sink "bluez_output.E9_A7_26_03_1E_82.1" is not available and does not appear. The script waits until "bluez_output.E9_A7_26_03_1E_82.1" is available.
k.s.deviate
It shows me it's connected and selected as the output device in the audio drop down.
It should be visible via pactl list sinks
k.s.deviate
It is
What is the output when you run hudiy_startup.sh manually?
k.s.deviate
cd ~/.hudiy/share/ $ ./hudiy_startup.sh cannot execute required file not found
k.s.deviate
Executing hudiy_run.sh opens terminal before trying to open Hudiy the terminal output is virtual const QPalette' Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::SystemPalette
Please verify that the hudiy_startup.sh has exactly the same content as we uploaded earlier, and check if the line endings are correct (dos2unix $HOME/.hudiy/share/hudiy_startup.sh).
It works for us locally so most probably your hudiy_startup.sh is somehow corrupted.
