After 2.4 update
k.s.deviate
Re: After 2.4 update
Now i understand why qpwgraphs flow looks the way it does after boot. Its the correct way.. I get audio now for some reason, it is crackly and a little quieter than expected but it seems to work. idk why now and not before.
Any ideas into the crackling at volume change? it seems to be the most audible while AA is open.
We tried to reproduce your setup. We connected headphones instead of a Bluetooth amplifier, but it should work the same way from PipeWire's perspective. Everything worked out of the box and we didn't observe any audio glitches. The routing generated by PipeWire looks identical.
pactl list sinks
pactl list sources
pactl list sinks
Sink #55
State: SUSPENDED
Description: Audio Adapter (Unitek Y-247A) Analog Stereo
Sample Specification: s16le 2ch 48000Hz
Volume: front-left: 26214 / 40% / -23.88 dB, front-right: 26214 / 40% / -23.88 dB
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
alsa.card = "0"
alsa.card_name = "USB Audio Device"
alsa.class = "generic"
alsa.components = "USB0d8c:0014"
alsa.device = "0"
alsa.driver_name = "snd_usb_audio"
alsa.id = "USB Audio"
alsa.long_card_name = "C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.3, full speed"
alsa.mixer_name = "USB Mixer"
alsa.name = "USB Audio"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.sync.id = "00000000:00000000:00000000:00000000"
api.alsa.card.longname = "C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.3, full speed"
api.alsa.card.name = "USB Audio Device"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "3"
device.api = "alsa"
device.class = "sound"
device.icon_name = "audio-card-analog"
device.id = "48"
device.profile.description = "Analog Stereo"
device.profile.name = "analog-stereo"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
device.description = "Audio Adapter (Unitek Y-247A)"
node.name = "alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo"
node.nick = "USB Audio Device"
object.path = "alsa:acp:Device:3:playback"
port.group = "playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "19"
client.id = "47"
object.id = "55"
object.serial = "55"
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.split-enable = "true"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
api.dbus.ReserveDevice1.Priority = "-20"
device.bus = "usb"
device.bus-id = "usb-C-Media_Electronics_Inc._USB_Audio_Device-00"
device.bus_path = "platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0"
device.enum.api = "udev"
device.name = "alsa_card.usb-C-Media_Electronics_Inc._USB_Audio_Device-00"
device.nick = "USB Audio Device"
device.plugged.usec = "6662726"
device.product.id = "0x0014"
device.product.name = "Audio Adapter (Unitek Y-247A)"
device.serial = "C-Media_Electronics_Inc._USB_Audio_Device"
device.subsystem = "sound"
sysfs.path = "/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/sound/card0"
device.vendor.id = "0x0d8c"
device.vendor.name = "C-Media Electronics, Inc."
spa.object.id = "2"
device.string = "0"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
Active Port: analog-output-speaker
Formats:
pcm
Sink #85
State: RUNNING
Description: WH-CH510
Volume: front-left: 42315 / 65% / -11.40 dB, front-right: 42315 / 65% / -11.40 dB
Monitor Source: bluez_output.74_45_CE_FF_FF_FF.1.monitor
Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
api.bluez5.address = "74:45:CE:FF:FF:FF"
api.bluez5.codec = "sbc"
api.bluez5.profile = "a2dp-sink"
api.bluez5.transport = ""
bluez5.loopback = "false"
card.profile.device = "1"
device.id = "79"
device.routes = "1"
factory.name = "api.bluez5.a2dp.sink"
device.description = "WH-CH510"
node.name = "bluez_output.74_45_CE_FF_FF_FF.1"
priority.driver = "1010"
priority.session = "1010"
spa.object.id = "1"
factory.id = "12"
device.api = "bluez5"
media.name = "WH-CH510"
object.id = "80"
object.serial = "85"
client.id = "47"
node.driver-id = "56"
api.bluez5.class = "0x240404"
api.bluez5.connection = "connected"
api.bluez5.device = ""
api.bluez5.icon = "audio-headset"
api.bluez5.path = "/org/bluez/hci0/dev_74_45_CE_FF_FF_FF"
bluez5.auto-connect = "[ hfp_hf hsp_hs a2dp_sink hfp_ag hsp_ag a2dp_source ]"
bluez5.profile = "off"
device.alias = "WH-CH510"
device.bus = "bluetooth"
device.form_factor = "headset"
device.icon_name = "audio-headset-bluetooth"
device.name = "bluez_card.74_45_CE_FF_FF_FF"
device.product.id = "0x223b"
device.string = "74:45:CE:FF:FF:FF"
device.vendor.id = "bluetooth:005d"
Ports:
headset-output: Headset (type: Headset, priority: 0, available)
Active Port: headset-output
Formats:
pcm
Sink #97
State: RUNNING
Description: hudiy_equalizer_sink Sink
Sample Specification: float32le 2ch 48000Hz
Owner Module: 536870916
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
Monitor Source: hudiy_equalizer_sink.monitor
Flags: DECIBEL_VOLUME LATENCY
node.name = "hudiy_equalizer_sink"
device.class = "filter"
audio.position = "[ FL, FR ]"
node.group = "ladspa-sink-536870916"
pulse.module.id = "536870916"
device.description = "hudiy_equalizer_sink Sink"
node.link-group = "filter-chain-1281-13"
node.virtual = "true"
resample.prefill = "true"
resample.disable = "true"
media.name = "hudiy_equalizer_sink Sink input"
stream.is-live = "true"
node.want-driver = "true"
node.autoconnect = "true"
adapt.follower.spa-node = ""
object.register = "false"
factory.id = "7"
client.id = "89"
object.id = "90"
object.serial = "97"
Formats:
pcm
Sink #112
State: RUNNING
Description: Echo-Cancel Sink
Owner Module: 536870917
Monitor Source: echo_cancel_sink.monitor
node.name = "echo_cancel_sink"
pulse.module.id = "536870917"
device.description = "Echo-Cancel Sink"
node.group = "echo-cancel-1281-14"
node.link-group = "echo-cancel-1281-14"
node.latency = "480/48000"
media.name = "Echo-Cancel Sink"
factory.id = "7"
client.id = "100"
object.id = "103"
object.serial = "112"
Formats:
pcm
Source #55
State: SUSPENDED
Name: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor
Description: Monitor of Audio Adapter (Unitek Y-247A) Analog Stereo
Monitor of Sink: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo
Flags: HARDWARE DECIBEL_VOLUME LATENCY
alsa.card = "0"
alsa.device = "0"
device.api = "alsa"
device.class = "monitor"
device.id = "48"
device.routes = "1"
factory.id = "19"
client.id = "47"
object.id = "55"
api.alsa.card = "0"
device.bus = "usb"
spa.object.id = "2"
device.string = "0"
Ports:
Formats:
pcm
Source #56
State: RUNNING
Description: Audio Adapter (Unitek Y-247A) Mono
Sample Specification: s16le 1ch 48000Hz
Channel Map: mono
Volume: mono: 65536 / 100% / 0.00 dB
Base Volume: 27111 / 41% / -23.00 dB
Monitor of Sink: n/a
alsa.card = "0"
alsa.device = "0"
api.alsa.path = "hw:0"
api.alsa.pcm.stream = "capture"
audio.channels = "1"
audio.position = "MONO"
card.profile.device = "2"
device.api = "alsa"
device.id = "48"
device.profile.description = "Mono"
device.profile.name = "mono-fallback"
device.routes = "1"
factory.name = "api.alsa.pcm.source"
media.class = "Audio/Source"
node.name = "alsa_input.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.mono-fallback"
object.path = "alsa:acp:Device:2:capture"
port.group = "capture"
priority.driver = "2000"
priority.session = "2000"
factory.id = "19"
client.id = "47"
object.id = "56"
object.serial = "56"
node.max-latency = "16384/48000"
api.alsa.period-size = "128"
api.alsa.period-num = "256"
api.alsa.headroom = "128"
api.alsa.card = "0"
device.bus = "usb"
spa.object.id = "2"
device.string = "0"
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
Active Port: analog-input-mic
Formats:
pcm
Source #85
State: RUNNING
Description: Monitor of WH-CH510
Monitor of Sink: bluez_output.74_45_CE_FF_FF_FF.1
device.id = "79"
device.routes = "1"
spa.object.id = "1"
factory.id = "12"
object.id = "80"
client.id = "47"
Ports:
Formats:
pcm
Source #97
State: RUNNING
Description: Monitor of hudiy_equalizer_sink Sink
Monitor of Sink: hudiy_equalizer_sink
factory.id = "7"
client.id = "89"
object.id = "90"
Formats:
pcm
Source #111
State: IDLE
Description: Echo-Cancel Source
node.name = "echo_cancel_source"
device.description = "Echo-Cancel Source"
media.name = "Echo-Cancel Source"
factory.id = "7"
client.id = "100"
object.id = "102"
object.serial = "111"
Formats:
pcm
Source #112
State: RUNNING
Description: Monitor of Echo-Cancel Sink
Monitor of Sink: echo_cancel_sink
factory.id = "7"
client.id = "100"
object.id = "103"
Formats:
pcm
k.s.deviate
Could it be that I dont have a defined source? I see you have the qtm-pulse stream.. set as input to the hudiy_equalizer_sink.hudiy wrote: Sun Jan 25, 2026 5:48 pm We tried to reproduce your setup. We connected headphones instead of a Bluetooth amplifier, but it should work the same way from PipeWire's perspective. Everything worked out of the box and we didn't observe any audio glitches. The routing generated by PipeWire looks identical.
QtmPulseStream on the screenshot is just a sink input (in this case from Android Auto). Sink inputs appear automatically once you start playback in any app (Hudiy, web browser, vlc, etc).
We also checked the PipeWire GitLab and found several issues regarding Bluetooth devices where volume control doesn't work. It’s possible your amplifier is one of those devices:
https://gitlab.freedesktop.org/pipewire ... ssues/3786
https://gitlab.freedesktop.org/pipewire ... ssues/4793
https://gitlab.freedesktop.org/pipewire ... ssues/3225
You can try to add your device to the /usr/share/spa-0.2/bluez5/bluez-hardware.conf and check if that helps.
{ address = "~^e9:a7:26:", no-features = [ hw-volume ]}, # DSP audio5.0 V1
k.s.deviate
I had a feeling I might be experiencing interference with bluetooth. I put a usb bluetooth adapter and swapped over to it and, everything works as expected. I had read somewhere that usb 3.0 devices interfere with bluetooth on the pi4, I'm using a usb 3.0 drive to boot from.
Would adding my device to ~/bluez-hardware.conf be advantageous?
If it is not the issue with volume control then you shouldn't modify bluez-hardware.conf.
If your setup works stable with external Bluetooth adapter it might indicate some incompatibility between your amplifier and built-in BRCM chip.
Kernel communicates with built-in Bluetooth chip via PL011 UART which seems to be unrelated to the USB.
k.s.deviate
From initial search, but there are documented accounts.
The Raspberry Pi 4 is widely known to experience radio frequency (RF) interference between its USB 3.0 ports and wireless signals, specifically Bluetooth and 2.4 GHz Wi-Fi. This interference occurs because the high-speed data transmission on USB 3.0 generates noise in the 2.4 GHz spectrum, which is the exact frequency used by Bluetooth.
Common Symptoms
Reduced Range: Bluetooth devices (keyboards, controllers, sensors) only work when within 1–2 meters of the Pi.
Connection Instability: Frequent disconnects, "stuttering" inputs, or failure to pair even if the device is detected.
Total Failure: In some cases, high-speed SSD activity on a USB 3.0 port can completely "jam" the Bluetooth controller.
Common Symptoms
We did some googling, and there are indeed a lot of reports that USB 3.0 causes interference with Bluetooth and 2.4GHz WiFi on Pi4. Thanks for pointing it out. Apparently, the problem doesn't occur when devices are connected to USB 2.0 ports.
k.s.deviate
Some weird behavior, audio still wont automatically play through the bluetooth dsp. A few days ago i could get audio to work by selecting the dsp in the audio dropdown and then going into Hudiy. This is qpwgraph after selecting it https://imgur.com/sVEixzk and here is a video and a few pictures showing what qpwgraph looks like immediately after exiting Hudiy.
https://imgur.com/SeZscUk https://imgur.com/B8bxgiU https://imgur.com/FV2T0Rz
https://imgur.com/5JgQQvu
However, now, (I changed nothing) I still have to select the dsp from the dropdown but qpwgraph looks like this https://imgur.com/vvHOFVj and it looks like this after exiting Hudiy https://imgur.com/cGkRdHA
Does your amplifier always connect to Bluetooth before Hudiy starts? Looking at qpwgraph, it seems like sometimes the echo cancel and equalizer load before the amplifier connects, causing WirePlumber to create different routing.
You could try adding a wait for a specific sink before Hudiy starts. Alternatively, you can specify a specific master for the echo-cancel module:
hudiy_startup.sh
Also remove the wireplumber cache:
hudiy_startup.sh
AMP_SINK="bluez_output.E9_A7_26_03_1E_82.1"
while ! sink_exists "$AMP_SINK"; do
done
sink_exists "$EC_SINK" || pactl load-module module-echo-cancel aec_method=webrtc aec_args=\"voice_detection=false\" source_name="$EC_SOURCE" sink_name="$EC_SINK" sink_master="$AMP_SINK"
$HOME/.hudiy/share/hudiy &Code: Select all
cd $HOME/.local/state/wireplumber
rm -rf *Hudiy Team
