CPU Load
toppsi
CPU Load
Post by toppsi »
Hi! I just migrated to a fresh Trixie system and got all my "old" widgets running.
I have a huge increase in CPU load when idling, now at 50% overall, where it was under 5% with Bookworm.
To me it seems the browser or whatever module that handles the html-widgets works another way.
Unfortunately this is a big issue, as my sound crackling (HifiBerry ADC+DAC) is directly correlated to CPU load.
I'm running on a RPi 4B.
Any thoughts on this?
Re: CPU Load
Are you using any advanced rendering in your widgets, such as canvas?
Please post the output of the wlr-randr command and provide more details about your screen setup. Also, if possible, please share the code for the widgets you are using.
toppsi
Re: CPU Load
Post by toppsi »
I was using the ODB-gauges widget (from examples) and forgot to setup the credentials in main_configuration.js with the new installation.
This was causing the high load.
I will show myself out... :oops:
