Hudiy operates in auto-negotiation mode for resolution and frame rate with CarlinKit dongles, which is the safest option to ensure that CarPlay works reliably across screens of various sizes and resolutions. In most cases, the frame rate should be 60 FPS. Manually setting the resolution and frame rate may cause CarPlay to fail to start in certain scenarios.
Mine definitely isnt, wired or wireless it’s not 60 for sure. Is there anything I can check on my side to see what could be upsetting it or causing a problem, ie my screen and sd card or peripherals.
However my actual screen will be a customized version of this screen below and 8hp. Custom cover glass, and the LCD from 8HP, for high colour gamut. With a Dsi interface like 8DSI-C model. All exhibit poor frame rate.
