Hi, I'm trying to understand how the DarkMode.py example changes state every 10 seconds based on
self._timer = threading.Timer(10, self.toggle_dark_mode, [client]).
Does deleting the timer and changing the value from zero to one in the "client.send(hudiy_api.MESSAGE_SET_DARK_MODE, 0" line still make the change?
I'd like to activate it based on a message from the CAN-BUS about the light status.
DarkMode
- Contact:
Re: DarkMode
Hello ElmodiLatta,
please check that one:
https://github.com/wiboma/hudiy/blob/ma ... proto#L686
// Id: MESSAGE_SET_DARK_MODE
// Receiver: Hudiy
// Description: Controls dark and light themes.
message SetDarkMode {
required bool enabled = 1;
if you break down that to a single line command it would be:
# Day (enabled = False)
# Night (enabled = True)
I am using also can bus for speed, rpm, light etc and added this functions to the eventhandler class:
And on the can bus part side of the script:
If you want to toggle like i do with a specific key:
If you want to send a initial state like i do, set this variable in the upper section of your script:
or
And put this in your "on_hello_response" from the EventHandler:
// Receiver: Hudiy
self.client.send(api.MESSAGE_SET_DARK_MODE, 0, api.SetDarkMode(enabled=False).SerializeToString())Code: Select all
self.client.send(api.MESSAGE_SET_DARK_MODE, 0, api.SetDarkMode(enabled=True).SerializeToString())I am using also can bus for speed, rpm, light etc and added this functions to the eventhandler class:
def _resolve_day_mode_for_toggle(self) -> bool:
if getattr(self, "_is_day_mode", None) is not None:
return self._is_day_mode
# If you want an initial system/app default, change this to False for Night.
return True
def send_day_night(self, mode: str) -> None:
try:
# --- Determine / toggle mode ----------------------------------------
if mode == "toggle":
base_is_day = self._resolve_day_mode_for_toggle()
is_day_mode = not base_is_day
elif mode in ("day", "night"):
is_day_mode = (mode == "day")
else:
raise ValueError("Invalid mode. Use 'day', 'night' or 'toggle'.")
# Update cache
self._is_day_mode = is_day_mode
# --- Check if transport is available --------------------------------
has_transport = (
getattr(self.client, "_socket", None) is not None
) or (
getattr(self.client, "_websocket", None) is not None
if not (api_is_connected and has_transport):
if ENABLE_LOGGING:
logger.warning("Client not connected – skipping send_day_night.")
return
# --- Send depending on backend --------------------------------------
if backend == "Hudiy":
# Hudiy expects SetDarkMode(enabled)
# Mapping: day -> enabled=False, night -> enabled=True
enabled = not is_day_mode
if ENABLE_LOGGING:
logger.info("Sending dark mode to Hudiy: enabled=%s", enabled)
msg = api.SetDarkMode()
msg.enabled = enabled
self.client.send(api.MESSAGE_SET_DARK_MODE, 0, msg.SerializeToString())
last_msg_635 = None
light_status = None
@handle_errors
async def process_canid_635(msg):
global light_status, last_msg_635
# Check if this is the first received message
first_message = last_msg_635 is None
if first_message or msg != last_msg_635:
# Extract byte 2 (light status from CAN)
light_value = int(msg[2:4], 16)
# Determine new status (0 = off, 1 = on)
if light_value > 0:
new_light_status = 1
else:
new_light_status = 0
# If first run or status has changed -> set mode
if first_message or (new_light_status != light_status):
if change_dark_mode_by_car_light and api_is_connected:
if new_light_status == 1:
mode = "night"
else:
mode = "day"
logger.info(f"Light status changed: Setting {mode} mode immediately.")
event_handler.send_day_night(mode)
# Update cached values
light_status = new_light_status
last_msg_635 = msgIf you want to toggle like i do with a specific key:
event_handler.send_day_night("toggle")Code: Select all
initial_day_night_mode = 'night' Code: Select all
initial_day_night_mode = 'day' And put this in your "on_hello_response" from the EventHandler:
# 🌗 Initial Day/Night Mode (bei dir aktuell auskommentiert)
if initial_day_night_mode == "day":
self.send_day_night('day')
pass
else:
self.send_day_night('night')
pass-
ElmodiLatta
Re: DarkMode
Thanks for all this information, some things with OpenAuto Pro were already done, here everything is a bit more complex for me as I am not very experienced in programming, I will read all the documentation calmly, with Arduino I read the CAN-BUS messages and then send the data via serial to the Raspberry, for now the rear camera works, the safe shutdown of the Raspberry when I turn off the car for the steering wheel controls I already have a few ideas I was just missing the light/dark part thanks again
