Can HUDIY work on other Linux SBC?
Just curious if HUDIY can run on other Linux SBC with higher performance?
Re: Can HUDIY work on other Linux SBC?
It should be doable if the Linux on that SBC uses standard kernel mechanisms (such as DRM, V4L2, NM). Which SBC do you have in mind exactly?
I'm thinking something like Jetson Orin and Lattepanda Sigma that have stronger compute system. LattePanda Sigma that runs Ubuntu and has build in Arduino Leonardo MCU for various control.
https://www.electromaker.io/blog/articl ... AM%20specs.
RockyHarder22
I've been playing around with the Radxa Zero3W3E. The minimal Armbian Debian 12 image works well on that board with a desktop added. The main issue I'm running into is hudiy wants a specific version of libboost (and the config file is different). I did get slash screen to display, but have to play with getting labwc on 12.
Orange Pi 5 and above. Very cool offering and I'm going to test it out after I get mine working with custom teensy controller board.
Anyone wanting to try it on x86 might want to try installing the Raspberry PI Desktop image: https://www.raspberrypi.com/software/operating-systems/
It's older Debian 11, but can be updated to Debian 12. Might provide a similar environment to on an actual raspberry pi.
