Hello, This is my project that replaced my entire OEM radio, I had the oem sync 3 with the 8 inch screen, non premium.
I'm loving this software so far.
This is by no means perfect, This is the first big project I've done like this, I did some coding, 3D design and the electrical circuit. So far everything that works is android auto, gauges, and some other things.
I'm using a usb sound card to Optical audio to a DSP that then goes to 2 separate amplifiers a 4 channel for my door (mids and highs) and a monoblock for my subwoofer
Future plans:
Steering wheel controls OEM (I have a canbus adapter on the way) - The canbus hasn't been able to sniff the controls, I have to go about this a different way now.
Rotary knob of some sorts.
Backup camera
Actual radio (RTL-SDR)
I'm sure ill add more.
BOM:
Hudiy
Raspberry Pi 5
52pi 7-inch Touch Capacitive screen
Aoicrie PC817 1 channel optocoupler isolation module (power safe shut down)
DROK Time delay relay (power shut down)
Geekworm X1001 Pcie to M.2 Hat
PlusRoc DC 12v/24v to 5V 5A step down converter (Supply stable power to the pi) -
Cm106 like usb Sound card
I would like to add the ability to watch my plex server, but im not great at coding and im having some issues understanding webview and such, any help is appreciated.
2014 Ford Escape SE
2014 Ford Escape SE
Re: 2014 Ford Escape SE
Here's some more progress, added a esp32 rotary knob for a physical button. Unfortunately I wasn't able to sniff out the canbus signals. But this was way more fun.
It does the following
Volume, mute, next, previous, pause, play, source change, eq.
The knob does a few other things, such as show song title and artist on the media screen. As well as the idle screen with the clock, I have a custom boot screen, with a custom sound from the headunit.
Update: the knob I used has become more problematic with encoder bounce then I like. I have the knob now receiving album art work as well as live updates from the song time and more.
That’s a really interesting integration. Regarding the encoder bounce issue, have you tried handling the debouncing directly on the ESP32 (using a timer or software filtering) rather than just at the application level? Given the number of functions you’re having it manage, that could also prevent double inputs during rapid rotation. The result—with the album art and real-time info display—looks really clean.
