Easy Bluetooth device switching
Giggig
Post by Giggig »
Both me and my partner drive the same car, the biggest gripe I have with hudiy since the beginning is that there's no easy way to switch between our two saved phones through the hudiy interface, I have to either unpair my phone through the hudiy interface and pair the other or I have to switch devices through the desktop environment, which is a bit of a hassle on a small 7inch display.
Is it possible to get some sort of saved devices menu to be implemented in some future release? or is there a way to get it working through a bit of coding?
Re: Easy Bluetooth device switching
Hudiy supports a maximum of one connected phone at a time. This is due to limited Bluetooth bandwidth. To quickly switch between Bluetooth devices, the easiest way is to initiate the connection from the phone. From your phone's Bluetooth settings, you can choose to connect to the Raspberry Pi. Hudiy will then automatically disconnect the Bluetooth of the currently connected phone and switch to the new connection.
