wifi adapter not on 5ghz
Skyline_tm
Post by Skyline_tm »
So I have hudiy installed on a pi zero 2 W and wanted to use a wifi 6 adapter from brostrend (AX900) as the pi zero 2 doesnt have internal 5ghz. Driver is installed, internal chip deactivated and to my home wifi the connection is on 5ghz. In the main confuguration file everything is set up for 5ghz but every time my phone connects on 2.4ghz for android auto. Even on 2.4ghz the wifi adapter says it supports up to 286Mbps but I am stuck at 86Mbps.
Re: wifi adapter not on 5ghz
Could you please post the contents of $HOME/.hudiy/share/config/main_configuration.json file? Please also post the output of dmesg command when hotspot is activated.
The 5GHz frequency is strictly regulated by local laws. The use of a 5GHz hotspot can be blocked by the system due to a missing Wi-Fi country setting in the Wi-Fi driver. Try adding the parameter cfg80211.ieee80211_regdom=PL in /boot/firmware/cmdline.txt (on the same line - cmdline.txt is a single-line file), replacing PL with your country code. As Pi Zero 2 does not have 5GHz-capable hardware, it is probably not set by default by the Raspberry PI OS (like for Pi 3B+, Pi 4B or 5).
Skyline_tm
these are the files. changing the country code didnt make any difference (i live in germany, so DE).
You do not need to set hardwareAddress in main_configuration.json if there is only one active wireless adapter in the system (built-in WiFi is disabled so we assume the only one active is the external wireless adapter).
According to the dmesg, wireless adapter still operates on 00 domain:
[   15.544261] AICWFDBG(LOGINFO)        getRegdomainFromRwnxDB set ccode:00
[   72.027948] usb 1-1.3 wlan0: AP started: ch=1, bcmc_idx=33 channel=2472 bw=1
so the 5GHz is probably still in NO-IR (No Initiating Radiation) mode.
You can try an alternative method for setting the country code:
1. Create cfg80211_regdomain.conf in /etc/modprobe.d/
sudo touch /etc/modprobe.d/cfg80211_regdomain.conf
2. Edit the /etc/modprobe.d/cfg80211_regdomain.conf file and add
sudo nano /etc/modprobe.d/cfg80211_regdomain.conf
options cfg80211 ieee80211_regdom=DE
3. Restart the Raspberry Pi.
If that doesn't work, you might need to set the country code directly in the driver (e.g., via an option) or directly in the code.
You can also try manually setting the channel to 36 to check if that enables the 5GHz in 00 domain (try 20MHz, 40MHz and 80MHz channel widths):
"channelConfigurationType" : "MANUAL",
"channelBandwidth" : "40MHz",
"channel" : 36
Skyline_tm
Thanks for the help. Apparently my adapter does not support hotspots on 5ghz because of hardware and security issues, which cause the country code to set back to 00 every time.
Is it possible though to use a wireless android auto dongle instead? As hudiy accepts the connection via usb.
We haven't tested Hudiy with wireless dongles, but it should probably work in the standard way.
You could also try using the built-in WiFi module of the Pi Zero 2 and setting the channel width to 40MHz. This should significantly increase throughput and in an environment with few WiFi networks around, the connection should be stable:
https://github.com/wiboma/hudiy/blob/ma ... -pi-zero-2
emeeder
Post by emeeder »
Okay... everything is working GREAT!!!
I have HUDiy grabbing wlan0 and doing it's thing, and my Pi5 also has wlan1 which connects to the internet for connections to the Google Gemini model and everything else!
My A.I. actually can mute HUDiy's music when I use the wake word I designed and un-mute when done, and I can connect with it via voice, Telegram and a small website with a Mic where it replies via voice play-back. (The A.I. can send me URLs and videos and maps, too!)
I have HUDiy's service controlled via my Python A.I. script so that it can stop and start it for me as well and stop itself for maintenance.
It's a pretty cool setup! Now I just need to get everything installed in the car before the July parades and car shows 😉👍
Thank you for all of your help, and if anyone needs help or ideas I'm usually available.
