Update to version 1.20 (Bookworm) and 2.16 (Trixie) is already available
Re: Update to version 1.20 (Bookworm) and 2.16 (Trixie) is already available
alex124.rh wrote: Tue Jun 09, 2026 10:24 am is the next version planned to include the colour theming update. I would appreciate this as it would really help advance the project
Yes, in the next version we plan to add the ability to override the theme colors (https://github.com/wiboma/hudiy#hudiycolorscheme-object) with custom values for both day and night modes. However, this won't be a feature that lets you change the color of any random UI element. What is your use case?
“As mentioned, around version 1.22/2.18, we will introduce the ability to override specific colors within the scheme calculated by Material Design (https://github.com/wiboma/hudiy/blob/ma ... eme-object).
This won't allow you to modify the color of every individual element on the interface. Instead, it will let you modify the color of a specific group of elements that share a color from that scheme (e. g. onSurface).
We are currently working on version 1.20/2.16. Releases generally come out on a monthly basis.”
The use case would be to for example change the colour of the text on the main dashboard. It needs to be green text on a night mode background to reduce strain on eyes.
Any info appreciated
Hi I answered with my use case so please can you reply what you think? Many thanks :D
The feature will allow you to override onSurface color which is used for most texts and icons.
Is there a way to modify the hudiy_equalizer_sink to make it 4.1, 5.1 and 7.1?
wkl3968 wrote: Thu Jun 11, 2026 7:11 am Is there a way to modify the hudiy_equalizer_sink to make it 4.1, 5.1 and 7.1?
hudiy_equalizer_sink is a virtual sink created by the equalizer plugin. PipeWire will automatically adjust the number of channels if upmix is enabled. If you have a physical device that supports 4.1/5.1, PipeWire will automatically configure the channel count.
You can check out this thread regarding the CM6206:
viewtopic.php?p=889#p889
I'm running CamillaDSP and 7.1 channels, 4 mono mics and I'm wondering how I can replace the Hudiy equalizer sink and echo cancel sink. Is the equalizer plugin can be edited or replaced?
The equalizer and echo cancel modules are loaded from $HOME/.hudiy/share/hudiy_startup.sh. You can change the module parameters or disable their loading by modifying this file.
