Installation error
Posted: Sun Oct 05, 2025 4:36 pm
by Criostior
I am attempting to install for the first time and am getting an error.
Error: Unable to locate package 'Libboost-json.81.0'
Error: Couldn't find any package by glob 'Libboost-json.81.0'
./installer: error while loading shared libraries: Libboost-json.81.0: cannot open shared object file: No such file or directory
Any guidance on how to rectify this?
Re: Installation error
Posted: Sun Oct 05, 2025 5:20 pm
Did you install Raspberry Pi OS Bookworm 64-bit Desktop? You can check it using the uname -a command. Could you paste the output of that command?
Posted: Sun Oct 05, 2025 6:09 pm
by Criostior
that appears to have been my issue. I accidently selected the trixie release not bookworm. thanks for the help
Posted: Sat Nov 01, 2025 5:14 pm
by Sambolini94
@Hudiy
I had to do a fresh install as per original method but just wondered, does it install V1.2? Or will it always install V1 and would need to use the built in update script for each new version including the latest one being V1.2?
Thanks,
Sam
Posted: Sat Nov 01, 2025 7:18 pm
Sambolini94 wrote: Sat Nov 01, 2025 5:14 pm
@Hudiy
Thanks,
Sam
The installer installs version 1.0, in case you ever need to roll back to an older release of Hudiy. You can update to version 1.2 using the updater right after installation. We plan to add automatic updater launch after installation to the installer soon.
Posted: Sat Nov 01, 2025 11:30 pm
by Sambolini94
Thank you for getting back to me and confirming my query, just these little aspects are good to know
