DarkMode
Posted: Mon Sep 22, 2025 9:07 am
by ElmodiLatta
Hi, I'm trying to understand how the DarkMode.py example changes state every 10 seconds based on
self._timer = threading.Timer(10, self.toggle_dark_mode, [client]).
Does deleting the timer and changing the value from zero to one in the "client.send(hudiy_api.MESSAGE_SET_DARK_MODE, 0" line still make the change?
I'd like to activate it based on a message from the CAN-BUS about the light status.
Thanks
Re: DarkMode
Posted: Mon Sep 22, 2025 12:03 pm
by noobychris
Hello ElmodiLatta,
please check that one:
https://github.com/wiboma/hudiy/blob/ma ... proto#L686
// Id: MESSAGE_SET_DARK_MODE
// Receiver: Hudiy
// Description: Controls dark and light themes.
message SetDarkMode {
required bool enabled = 1;
if you break down that to a single line command it would be:
# Day (enabled = False)
self.client.send(api.MESSAGE_SET_DARK_MODE, 0, api.SetDarkMode(enabled=False).SerializeToString())
# Night (enabled = True)
self.client.send(api.MESSAGE_SET_DARK_MODE, 0, api.SetDarkMode(enabled=True).SerializeToString())
I am using also can bus for speed, rpm, light etc and added this functions to the eventhandler class:
def _resolve_day_mode_for_toggle(self) -> bool:
	if getattr(self, "_is_day_mode", None) is not None:
		return self._is_day_mode
	# If you want an initial system/app default, change this to False for Night.
	return True
def send_day_night(self, mode: str) -> None:
    try:
        # --- Determine / toggle mode ----------------------------------------
        if mode == "toggle":
            base_is_day = self._resolve_day_mode_for_toggle()
            is_day_mode = not base_is_day
        elif mode in ("day", "night"):
            is_day_mode = (mode == "day")
        else:
            raise ValueError("Invalid mode. Use 'day', 'night' or 'toggle'.")
        # Update cache
        self._is_day_mode = is_day_mode
        # --- Check if transport is available --------------------------------
        has_transport = (
            getattr(self.client, "_socket", None) is not None
        ) or (
            getattr(self.client, "_websocket", None) is not None
        if not (api_is_connected and has_transport):
            if ENABLE_LOGGING:
                logger.warning("Client not connected – skipping send_day_night.")
            return
        # --- Send depending on backend --------------------------------------
        if backend == "Hudiy":
            # Hudiy expects SetDarkMode(enabled)
            # Mapping: day -> enabled=False, night -> enabled=True
            enabled = not is_day_mode
            if ENABLE_LOGGING:
                logger.info("Sending dark mode to Hudiy: enabled=%s", enabled)
            msg = api.SetDarkMode()
            msg.enabled = enabled
            self.client.send(api.MESSAGE_SET_DARK_MODE, 0, msg.SerializeToString())
And on the can bus part side of the script:
last_msg_635 = None
light_status = None
@handle_errors
async def process_canid_635(msg):
    global light_status, last_msg_635
    # Check if this is the first received message
    first_message = last_msg_635 is None
    if first_message or msg != last_msg_635:
        # Extract byte 2 (light status from CAN)
        light_value = int(msg[2:4], 16)
        # Determine new status (0 = off, 1 = on)
        if light_value > 0:
            new_light_status = 1
        else:
            new_light_status = 0
        # If first run or status has changed -> set mode
        if first_message or (new_light_status != light_status):
            if change_dark_mode_by_car_light and api_is_connected:
                if new_light_status == 1:
                    mode = "night"
                else:
                    mode = "day"
                logger.info(f"Light status changed: Setting {mode} mode immediately.")
                event_handler.send_day_night(mode)
        # Update cached values
        light_status = new_light_status
        last_msg_635 = msg
If you want to toggle like i do with a specific key:
event_handler.send_day_night("toggle")
If you want to send a initial state like i do, set this variable in the upper section of your script:
initial_day_night_mode = 'night'
or
initial_day_night_mode = 'day'
And put this in your "on_hello_response" from the EventHandler:
            # 🌗 Initial Day/Night Mode (bei dir aktuell auskommentiert)
            if initial_day_night_mode == "day":
                self.send_day_night('day')
                pass
            else:
                self.send_day_night('night')
                pass
Re: DarkMode
Posted: Mon Sep 22, 2025 12:31 pm
by ElmodiLatta
Thanks for all this information, some things with OpenAuto Pro were already done, here everything is a bit more complex for me as I am not very experienced in programming, I will read all the documentation calmly, with Arduino I read the CAN-BUS messages and then send the data via serial to the Raspberry, for now the rear camera works, the safe shutdown of the Raspberry when I turn off the car for the steering wheel controls I already have a few ideas I was just missing the light/dark part thanks again
