CarPlay lagging
Posted: Fri Sep 05, 2025 5:46 am
by Nonspeaker008
Hi everyone ,
My setup is PI5 8gb, Hifiberry digi2 pro, cooler, Waveshare 9.3HDMI, and Carplay CarlinKit CPC200-CCPA,
A problem is that ewerythin fly good (sound not tested yet)
But carplay is lagging and feels slowish I guess ,(HUDIY soft runs supper well no delay I'd say) is there any fix for it or it's as good as it can be TX ;)
Re: CarPlay lagging
Posted: Fri Sep 05, 2025 7:47 am
Hello, could you please send the output of the wlr-randr command? We’ll check the refresh rate, since it affects rendering.
Re: CarPlay lagging
Posted: Sun Sep 07, 2025 10:50 am
by Nonspeaker008
pi@raspberrypi:~ $ wlr-randr
HDMI-A-1 "Wavephore WaveShare_093 0x00000002 (HDMI-A-1)"
Physical size: 240x100 mm
Enabled: yes
Modes:
720x400 px, 70.082001 Hz
640x480 px, 59.939999 Hz
640x480 px, 60.000000 Hz
800x600 px, 60.317001 Hz
1024x768 px, 60.004002 Hz
1280x720 px, 59.939999 Hz
1280x720 px, 60.000000 Hz
1280x1024 px, 60.020000 Hz
1920x1080 px, 59.939999 Hz
1920x1080 px, 60.000000 Hz
1600x600 px, 59.993000 Hz (preferred, current)
Position: 0,0
Transform: normal
Scale: 1.000000
Re: CarPlay lagging
Posted: Sun Sep 07, 2025 10:53 am
by Nonspeaker008
Hudiy software runs perfect but when i tun on carplay (inside carplay) its laggy especialy in comparison with Hydiy interface
Re: CarPlay lagging
Posted: Sun Sep 07, 2025 5:56 pm
Thanks for the output. Some displays report a refresh rate slightly lower than 60 Hz (by very small fractional values), but in practice they do support 60 Hz. In the new version, we’ve added some improvements to FPS negotiation with CarPlay/Android Auto based on the reported refresh rate. There will also be an option to manually set the FPS. This should make the projection smoother.
Currently, Hudiy is also running in the X11 compatibility layer. In the new version, it will be possible to run Hudiy fully on Wayland.
The new version will be released on September 15.
