Brightness & color adjustment.
Posted: Sun Aug 30, 2026 9:31 am
by bartp
Is it possible to implement it in hudiy?
Re: Brightness & color adjustment.
Posted: Sun Aug 30, 2026 10:02 am
It is possible to add a shader that will change RGBA values on the fly and this shouldn't impact the performance. Currently, there are controls available in the settings to adjust the theme contrast which work in similar way. By default, Hudiy forces the system to use a 24-bit color palette, so color reproduction should be undistorted.
https://github.com/wiboma/hudiy/blob/ma ... ace_format
What exact screen are you using and what color issues are you experiencing in your setup?
