Touchscreen not working with Waveshare 8-DSI-TOUCH-A on RPi3
Posted: Sat Aug 01, 2026 1:19 pm
I am building a custom head unit using Hudiy on a Raspberry Pi 3B. While the display works and rotates correctly, the touchscreen completely fails to respond after boot. However, if I stop Hudiy and switch to the OS desktop, the touchscreen works perfectly.
Here is my hardware and software environment:
- **Hardware:** Raspberry Pi 3B, Waveshare 8-inch DSI Touch Display (8-DSI-TOUCH-A, 800x1280), Creative Sound Blaster X-Fi Go Pro USB
- **OS:** Raspberry Pi OS / Debian Trixie (64-bit)
### Current Symptoms:
1. When running Hudiy (in EGL/framebuffer mode), the display orientation is correct, but touch input is completely unresponsive.
*I have changed setting "rotation" : "LEFT", in main_configuration.json
2. When stopping Hudiy and starting the OS desktop (`sudo pkill hudiy` -> `sudo init 5`), the screen is rotated to landscape, and touch inputs work properly (tested via OS environment and `evtest`).
### Configuration Files:
$ cat /boot/firmware/config.txt | grep dto
dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-waveshare-panel-v2,8_0_inch_a
dtoverlay=dwc2,dr_mode=host
$ cat /boot/firmware/cmdline.txt
console=serial0,115200 console=tty1 root=PARTUUID=b099dfef-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=JP video=DSI-1:800x1280e,rotate=90 logo.nologo vt.global_cursor_default=0 loglevel=0 quiet splash plymouth.ignore-serial-consoles
$ cat /etc/udev/rules.d/99-waveshare-touch.rules
#90°:
ENV{ID_INPUT_TOUCHSCREEN}=="1", ENV{LIBINPUT_CALIBRATION_MATRIX}="0 -1 1 1 0 0"
#90°:
