Dashboard Widget: CPU Monitor
charpeasy
Re: Dashboard Widget: CPU Monitor
Post by charpeasy »
Thank you very much appreciate the help I got the widget to come on the dash board but the values are blank
Tommiedw
Post by Tommiedw »
Hi guys, thought I'd share some custom enhanced widgets for CPU Monitoring
cpu_widget.rar
HTML and Python script
(4.03 KiB) Downloaded 31 times
Take note this has been done on Raspberry Pi 5 not sure if works on Pi 3 and 4?
Autyzmiasty
Post by Autyzmiasty »
This new script with voltage and amps still doesn’t work for me, lol. At first it didn’t show volts, memory usage, or amps at all — I figured out why: the frontend was expecting different data than what the backend was sending. After fixing that, CPU voltage for example shows 1V and 0A.
