New/different Touchscreen won't start using old settings
Posted: Fri Jul 17, 2026 5:35 pm
I originally had a 8" Touchscreen that launched perfectly.
Unfortunately I had to switch to a 8.9" Magedok Touchscreen and it just keeps blinking out and never seems to launch correctly. By the way when I did not allow your software to launch the new touch screen put it up perfect, so I know it's got to be something with the settings with your app.
Here is the settings for androidAuto in the config file...
"androidAuto" : {
"speechAudio" : true,
"mediaAudio" : true,
"resolution" : "720p",
"bluetoothAddress" : "",
"autostart" : true,
"fps" : "30",
"dpi" : 160,
"widthMargin" : 0,
"heightMargin" : 0,
"width" : 0,
"height" : 0,
"x" : 0,
"y" : 0,
"gpsDataSource" : "GPSD",
"useRpiDrm" : false,
"dayNightMode" : "COMMON"
What should I tweak/change to get this new unit launching properly? (Quick responses please because I am on a time crunch this week to get this installed Monday.)
The androidAuto section was the only thing I changed from the default. I don't remember what the default was, and I'm not sure what I did here that might not be happy to the new monitor.
"androidAuto" : {
"autostart" : true,
"fps" : "30",
"dpi" : 160,
"widthMargin" : 0,
"heightMargin" : 0,
"width" : 0,
"height" : 0,
"x" : 0,
"y" : 0,
