Android Auto and how it would handle 2 WiFi connections
Posted: Fri Jun 12, 2026 6:24 pm
by emeeder
I need to always have access to a "free" WiFi connection for a separate python project.
Will the HUDiy/AA system always only use wifi-0 to grab the pipeline to to my phone, or will it sometimes grab wifi-1 if it's free?
Re: Android Auto and how it would handle 2 WiFi connections
Posted: Fri Jun 12, 2026 10:54 pm
By default, Hudiy uses the first available Wi-Fi adapter to create a hotspot. The order of the adapter is controlled by NetworkManager from Raspberry Pi OS.
You can also specify the hardware address of the Wi-Fi adapter to be used for creating the hotspot in main_configuration.json:
https://github.com/wiboma/hudiy/blob/ma ... md#hotspot (hardwareAddress)
Posted: Sat Jun 13, 2026 10:34 am
by emeeder
Perfect... thank you!
Posted: Sun Jun 14, 2026 12:02 pm
by emeeder
Okay... I've got the Raspberry Pi 5 running with the two WiFi cards (wlan0 and wlan1), and I tried to put the MAC address of wlan1 into the "hardwareAddress" field of the main_configuration.json file under hotspot but for some reason it just didn't work.
(Now at least it didn't blow up the Pi's SSH/RDP/sFTP pipes, but HUDiy just sat there and AA wouldn't start.)
Is there something else from the default settings that I need to tweak in order for the HUDiy/AA stuff to launch using the wlan1 instead, or am I just having terrible luck?
Posted: Sun Jun 14, 2026 12:19 pm
Is the hotspot icon visible in the status area next to the clock? Are you able to connect to the hotspot from other devices?
USB Wi-Fi adapters may have limitations when creating 5GHz hotspots because the 5GHz band is strictly regulated by local laws in most countries. You can check this thread:
viewtopic.php?t=233
Posted: Mon Jun 15, 2026 10:16 pm
by emeeder
Everything is working GREAT!
Dual WiFi connections, 24/7 (basically) access to Gemini 3.1 model for A.I. interactions, smart home access, Google calendar, tasks, shopping list, and alarms
Mute AA music with wake-word... very clean.
HUDiy is controlled by the Python script with touchscreen power on/off.
