Page 1 of 3
Update to version 1.20 (Bookworm) and 2.16 (Trixie) is already available
Posted: Sun May 31, 2026 10:21 pm
We are happy to announce that Hudiy 1.20/2.16 is now available. You can find the release highlights below:
Web Viewer
Web Viewer is a standalone application that displays a provided URL using the Chromium engine. The URL can be displayed in Window, Frameless Window, or Offscreen modes. Offscreen mode is a special mode used to stream the display of the provided URL. The image is streamed to a device (e.g., Raspberry Pi Pico 2) via USB CDC in a compressed JPEG format. Web Viewer makes using SPI screens easier and gives you the possibility to build your own custom gauges - for example, by displaying widgets on rounded displays connected to the Raspberry Pi Pico 2. More details and examples are available on our GitHub:
https://github.com/wiboma/hudiy/blob/ma ... web-viewer
https://github.com/wiboma/hudiy/tree/ma ... al_display
Analog clock widget
We have added a built-in analog clock widget. If you are using a Raspberry Pi Zero 2 and want to have an analog clock as a widget in the Dashboard, using the built-in widget will save RAM compared to the HTML version.
Improvements
  • Improved UI flexibility for narrower displays.
  • Thanks to small optimizations, we managed to slightly increase USB throughput in communication with the CarlinKit Dongle.
  • Added an additional menu to preview notification content from the Android Companion app.
Companion App (Android)
Improved Bluetooth connection establishment with the Hudiy service.
Web Viewer demo
Re: Update to version 1.20 (Bookworm) and 2.16 (Trixie) is already available
Posted: Sun May 31, 2026 10:24 pm
by noobychris
Hello dear hudiy team,
did you bring these two feature requests into this release?
viewtopic.php?t=245
viewtopic.php?t=127
Couldn't find any changes in https://github.com/wiboma/hudiy/blob/ma ... rlays.json and https://github.com/wiboma/hudiy/blob/ma ... rlays.json
Thanks,
Chris
Posted: Sun May 31, 2026 10:34 pm
noobychris wrote: Sun May 31, 2026 10:24 pm Hello dear hudiy team,
viewtopic.php?t=245
viewtopic.php?t=127
Thanks,
Chris
Not yet, unfortunately, but they will be available in the next release in June. This feature needs a bigger overlay rework than planned and we haven't finished it yet due to the release for Pi Zero 2/3B/3B+.
As a workaround for now, a simple Python script might be enough to recalculate the overlay coordinates proportionally to the base and current screen resolutions.
Posted: Mon Jun 01, 2026 3:27 am
Great addition Hudiy!! Recently I bought the Waveshare RP2350 Round AMOLED display thinking of adding a dedicated analog clock and custom navigation display. Your upgrade makes my life easier.. keep it up!
Posted: Mon Jun 01, 2026 5:41 pm
by Zyox
Are you using a separate piZero there to run the 1.28 display?
Could this be done using only one raspi4/5 with a primary large display and a secondary 1.28?
Posted: Fri Jun 05, 2026 9:09 pm
by jackv8
Awesome update! I have a free spot in my E39 for such display and I think this one should fit https://www.waveshare.com/wiki/1.47inch_LCD_Module. Will it work with any available firmware?
Posted: Fri Jun 05, 2026 10:56 pm
jackv8 wrote: Fri Jun 05, 2026 9:09 pm Awesome update! I have a free spot in my E39 for such display and I think this one should fit https://www.waveshare.com/wiki/1.47inch_LCD_Module. Will it work with any available firmware?
According to the driver source code in the Waveshare examples, the command opcodes are the same. The difference is in the init sequence and the display's parameters (width, height). This type of display is available in our country - we will try to get one and add support for it to the firmware.
Posted: Tue Jun 09, 2026 5:42 am
Hi Hudiy, is there a way to customize the UI looks and feel? Basically completely overhaul the main page of Hudiy.
Posted: Tue Jun 09, 2026 9:38 am
wkl3968 wrote: Tue Jun 09, 2026 5:42 am Hi Hudiy, is there a way to customize the UI looks and feel? Basically completely overhaul the main page of Hudiy.
Yes, you can create your custom UI using HTML/Javascript, add it as an application to the $HOME/.hudiy/share/config/applications.json and then use it as a main screen:
https://github.com/wiboma/hudiy/blob/ma ... pplication (defaultAction)
https://github.com/wiboma/hudiy/blob/ma ... plications
Posted: Tue Jun 09, 2026 10:24 am
is the next version planned to include the colour theming update. I would appreciate this as it would really help advance the project
