Change Widget Size to Fullscreen
Posted: Thu May 14, 2026 6:18 pm
by proteinklumpen
Hey,
I am currently building multiple dashboards. My problem is, that widgets maximum size is large_wide, which is not the fullscreen. I always have empty spaces left or right. Even on self written .html files which would be fullscreen able. How can I implement them into a dashboard and use all of my space?
Is it possible to make this also available for now_playing? I dont want anything else on this monitor (I have a multi monitor setup). But large_wide is not big enough. If not, could you tell me how you recieve those information? So maybe I can develope my own Widget
Thanks in advance!
Sandro
Re: Change Widget Size to Fullscreen
Posted: Thu May 14, 2026 8:05 pm
If you'd like to display something in full screen, it's best to use Overlays for that. You can check out our idle screen example and build your own based on it:
https://github.com/wiboma/hudiy/tree/ma ... dle_screen
Posted: Mon Jun 08, 2026 8:53 pm
by proteinklumpen
Thanks worked perfectly!
