Page 1 of 2
HifiBerry DAC8x
Posted: Tue Apr 07, 2026 2:39 pm
Just started testing the HifiBerry DAC8x as shown in the photo. it works for Channel 1 and 2 Stereo out of the box with the right config.txt. dtoverlay=hifiberry-dac8x. I also tried to duplicate the 1-2 channels to channel 3 to 8 using qpwgraph as shown in the photo but the setting is not sustained after reboot. still need to figure out how to approach this. the main reason I want to use a hifiberry DAC8x because of the hires audio support, can setup different sound stage (4.1, 5.1, 7.1 and etc) and most importantly, I want the phone call or phone navigation only output from certain channels (not all). Im looking for guidance on how to do this.
Re: HifiBerry DAC8x
Posted: Tue Apr 07, 2026 2:42 pm
Here is the hardware setup. It is sleek and high quality. I need to spend time to setup correctly and have the ability to customize the audio piping. Any guidance will be appreciated.
Re: HifiBerry DAC8x
Posted: Tue Apr 07, 2026 7:33 pm
After configuring the routing using qpwgraph, you can save it to a file and restore it (e.g., in hudiy_startup.sh) using the following command:
qpwgraph --minimized --activated --exclusive saved_routing.qpwgraph
viewtopic.php?p=1184#p1184
Re: HifiBerry DAC8x
Posted: Wed Apr 08, 2026 2:32 am
Is it possible to pipe the Bluetooth or phone call or navigation from phone to a certain channels and have independent volume control?
Re: HifiBerry DAC8x
Posted: Mon Apr 13, 2026 11:34 am
so the hudiy_startup.sh should look like this? with so many customization I plan to do with hudiy, is there a way I can use github to allow me to reconfigure the a freshly installed hudiy seamlessly? I'm a mechanical side, learning software :).
sink_exists "$EC_SINK" || pactl load-module module-echo-cancel aec_method=webrtc aec_args=\"voice_detection=false\" source_name="$EC_SOURCE" sink_name="$EC_SINK"
Re: HifiBerry DAC8x
Posted: Tue Apr 14, 2026 3:18 am
Hudiy team, please help my questions above?
Re: HifiBerry DAC8x
Posted: Tue Apr 14, 2026 3:27 am
wkl3968 wrote: Tue Apr 14, 2026 3:18 am Hudiy team, please help my questions above?
It depends on which version of the Raspberry Pi you are using. If it's a Pi 4 or Pi 5, such script will work on those versions as well as on x86_64. The Raspberry Pi Zero 2, Pi 3B, and Pi 3B+ additionally set different environment variables.
The easiest way is to copy the configuration ($HOME/.hudiy/share/config) and the scripts ($HOME/.hudiy/share/hudiy_startup.sh, $HOME/.hudiy/share/hudiy_run.sh), and then restore them after installing Hudiy.
Re: HifiBerry DAC8x
Posted: Wed Apr 15, 2026 8:37 am
somehow when I use the "qpwgraph --minimized --activated --exclusive /home/raspberrypi/AA_DAC8x.qpwgraph" as instructed above, hudiy fail to boot and it keeps looping the splash only.
Re: HifiBerry DAC8x
Posted: Wed Apr 15, 2026 9:45 am
qpwgraph may be blocking the current terminal session. Try running qpwgraph --minimized --activated --exclusive /home/raspberrypi/AA_DAC8x.qpwgraph in the background by adding & at the end of the command.
Also, in background mode, some sleep might be a good idea to give qpwgraph some time to restore the routing.
qpwgraph --minimized --activated --exclusive /home/raspberrypi/AA_DAC8x.qpwgraph &
sleep 2
If that does not help, please execute the $HOME/.hudiy/share/hudiy_run.sh command in the terminal and post the output.
Re: HifiBerry DAC8x
Posted: Wed Apr 15, 2026 3:27 pm
now it can boot like normal with "&" at the back but somehow it cannot sustain the connection between Hudiy FL/FR to the 8 channels as shown in my first post. it always default to just two channels output.
