Update to version 1.16 (Bookworm) and 2.12 (Trixie) is already available
Posted: Sun Mar 29, 2026 7:55 pm
We are happy to announce that Hudiy 1.16/2.12 is now available. You can find the release highlights below:
Direct renderer
In version 2.8, we introduced the direct renderer, which is optimized specifically for CarPlay and Android Auto video streams. Initially, it was designed for console mode on lower-end Raspberry Pi models (Pi Zero 2, Pi 3B, and Pi 3B+). In current release, we successfully ported the direct renderer to the Raspberry Pi 4B, Raspberry Pi 5 and x86_64 with VAAPI support.
Thanks to the direct renderer, video playback is more efficient and smoother due to tailored optimizations for CarPlay and Android Auto.
Starting with this release, the direct renderer is the default for Raspberry Pi in both desktop and console modes. The composition renderer will still be available and you can easily switch between them using the HUDIY_RENDERER environment variable.
Due to hardware diversity (GPU, VPU) on x86_64, the composition renderer remains the default on this platform since it is more universal. However, if your x86_64 hardware supports VAAPI, you can switch to the direct renderer using the HUDIY_RENDERER environment variable.
https://github.com/wiboma/hudiy/blob/ma ... y_renderer
Ring buffer optimizations
We also introduced optimizations to the ring buffer implementation. As a result, processing the projection data (video and audio) can be up to 12% faster, depending on the platform (L2 cache capacity) and resolution. This results in lower latency and reduced CPU and RAM usage.
Re: Update to version 1.16 (Bookworm) and 2.12 (Trixie) is already available
Posted: Mon Mar 30, 2026 1:32 am
Wow.. I always looking forward for each month ends for updates. Keep up the excellent work HUDIY!!
Posted: Wed Apr 01, 2026 6:01 pm
by korni92
This is huge improvment
Posted: Thu Apr 02, 2026 12:39 am
Pi5 price has increased. So I plan to use my leftover pi4. May I know which hudiy version can be used for pi4?
Posted: Thu Apr 02, 2026 7:55 am
wkl3968 wrote: Thu Apr 02, 2026 12:39 am Pi5 price has increased. So I plan to use my leftover pi4. May I know which hudiy version can be used for pi4?
For Pi4 you can use both 1.16 (Bookworm) and 2.12 (Trixie). If you don't have a specific reason to use Bookworm (e. g. older version of the kernel), we recommend Trixie as it's the current OS version actively maintained by the Raspberry Pi Foundation. Trixie also supports Bluetooth cover art and 80MHz channel width in WiFi hotspots.
Posted: Fri Apr 10, 2026 3:21 pm
I use the latest installer and then I perform update. It straight away update to 2.12 for Trixie. How to do version to version update?
Posted: Fri Apr 10, 2026 10:40 pm
Due to the release of the direct renderer, the version currently being installed is 1.16/2.12 (1.x - Bookworm, 2.x - Trixie). If you are installing Hudiy after the 1.16/2.12 release, the installer will automatically install this version (which is currently the latest).
A version-by-version update is only required if your current Hudiy version is several versions behind, like 2.4. In that case (2.4), with each updater launch, the updater will incrementally update the software as follows:
2.4 -> 2.6
2.6 -> 2.8
2.8 -> 2.10
2.10 -> 2.12
It works this way to prevent any potential corruption to your operating system or your Hudiy installation.
Posted: Sat Apr 11, 2026 12:18 am
Finally I got the 2.12 running. I have been using bookworm for 1.2 version. When running 2.12, there flashes of desktop screens. Is this given? Also it took longer to boot Trixie?
Posted: Sat Apr 11, 2026 1:01 am
We didn't observe any differences between Bookworm and Trixie boot times. Regarding the desktop screen appearing during Hudiy startup, you can check:
viewtopic.php?p=453#p453
viewtopic.php?p=1381#p1381
Posted: Sun Apr 12, 2026 6:20 am
The speed of the SDcard makes a big difference in boot time. Thanks for the help.
