Waydroid app launch
Posted: Wed Mar 25, 2026 2:44 am
by Crombie
Im using some of the coding from
To create a menu button for a android app launched with waydroid. I have successfully created the menu and it launches the app. But when I go to access other areas of hudiy the android app looses focus and I cant bring it back to the front.
Is there a better solution?
The code i am using is
from flask import Flask
import subprocess
import os
app = Flask(__name__)
def run_game(cmd):
    env = os.environ.copy()
    # Required for Waydroid / GUI apps
    env["DISPLAY"] = os.environ.get("DISPLAY", ":0")
    env["WAYLAND_DISPLAY"] = os.environ.get("WAYLAND_DISPLAY", "wayland-0")
    env["XDG_RUNTIME_DIR"] = os.environ.get("XDG_RUNTIME_DIR", f"/run/user/{os.getuid()}")
    # Optional
    env["DBUS_SESSION_BUS_ADDRESS"] = os.environ.get("DBUS_SESSION_BUS_ADDRESS", "")
    subprocess.Popen(cmd, env=env)
# apps
@app.route("/draiver")
def draiver():
    run_game(["waydroid", "app", "launch", "com.driverdo"])
    return "Draiver launched!", 200
# flask
if __name__ == "__main__":
    app.run(host="0.0.0.0", port=44408)
Re: Waydroid app launch
Posted: Wed Mar 25, 2026 10:52 am
You can try using wlrctl (sudo apt install wlrctl) to bring the window to the front.
In your script (in /draiver), you can check if your application is already running (e.g., if it appears on the list returned by wlrctl toplevel list), and if so, call:
wlrctl toplevel focus app_id:your_app_name
and if not, simply launch it.
https://manpages.debian.org/trixie/wlrc ... .1.en.html
Posted: Wed Mar 25, 2026 3:03 pm
by Crombie
Thanks for the reply. It is a option I was looking at but is there a way to do this through some UI changes so that it only displays on screens that i want?
The app i want to launch will always be in a static location and size.
So ideally I would like hudiy UI just to show that area of the desktop. And then change the width of android auto so it doesnt cover that area up as well.
