noob questions
Posted: Fri Feb 13, 2026 8:29 pm
i just found this software. im building a customized 1978 el camino with and newer ls motor upgrade, so it has a can bus, and decided to build a 20" touchscreen radio in new dash. that part works great but im not sure how to add
backup camera
sdr tuner to work
get audio out to amps, currently trying bluetooth or line out on usb adapter both are low volume with every volume setting i can locate maxed out
i'm running bookworm, is trixie better? it keep having install issues on trixie, bookworm worked right away. i read in a forum post that trixie need a newer hudiy installer
how do i get the custom gauge pods?
i know nothing about this ios environment, but am a computer engineer can figure it out with a good tutorial
is there a good noob walkthrough?
id also like to add fuel level to gauge output i was going to install digital dash in the car but it looks like i car do dual display and make the gauge output i need speed/tack/ fuel?
google searches for any of this come up with hyundai radio answers
thank you
backup camera
sdr tuner to work
thank you
