FM-Radio: distorted audio, ok with rtl_fm player
Posted: Sat Feb 07, 2026 7:17 pm
by Andertam
Dear Co-Hudiyers,
using a Nooelec, NESDR SMArt v5 rtl-SDR receiver with default settings ("autoGain" : true, "squelchLevel" : 350 and "squelchLimit" : 10) I only get distorted audio via either BT or Soundcard output.
It significantly improves if I reduce the manual gain to below 280 but then end up in instable station search where the revceiver locks to frequencies already 50KHz before or after the 'good' sender frequency (depending on scan direction). I was not successful in fixing this by fine tuning squelch settings: either the lock is 50KHz off or station is not found.
If I operate the stick with 'rtl_fm -f 98.5e6 -s 96000 -E deemp' (default gain:auto, squelch-level=0) I get a cristal clear audio (Hudiy active).
I installed the latest module and libraries including blacklisting unused modules to no avail.
My setup is Hudiy 2.4 (default configuration) on Pi5, Debian Trixie, 3A orig. PI power supply, Audio via: StarTech.com USB 2.0 Soundbox 7.1
Re: FM-Radio: distorted audio, ok with rtl_fm player
Posted: Sat Feb 07, 2026 8:32 pm
Thanks for reporting. Hudiy utilizes its own algorithms for both communicating with the RTL chip and demodulating FM signal. Our testing was primarily conducted using V3 dongles. We will review the datasheets for the newer versions of RTL-SDR chip to investigate the source of the discrepancy in signal quality.
Posted: Sun Feb 15, 2026 9:45 pm
Good news. We've identified potential behavior differences between v3 and v4/v5. We're just waiting for the shipment with the v4/v5 dongle to run the tests on real hardware.
Posted: Thu Feb 26, 2026 5:53 pm
Version with the improvements has been released viewtopic.php?p=1310#p1310
Posted: Mon Mar 02, 2026 7:21 am
by Andertam
Thank you Hudiy team,
I confirm the issue solved for Nooelec, NESDR SMArt v5 rtl-SDR receiver with the latest update.
