GPS coordinates etc. from AA
Posted: Mon Feb 02, 2026 8:07 am
by Hummer
Hi
Is is possible to tap into the GPS information from AA or even get the gps coordinates from the companion app?
I would give me the option to create a overspeed warning without connecting another gps dongle to my rpi.
Re: GPS coordinates etc. from AA
Posted: Mon Feb 02, 2026 7:11 pm
Android Auto only allows for sending GPS data from external source. This means that by using Hudiy and GPSD, you can transmit data to Android Auto, e. g. from a GPS module connected to the Raspberry Pi. The companion app does not have a mechanism for exchanging GPS data between Hudiy and the phone. To do this via a dedicated app, it would be best to use Bluetooth and a custom service, as Android Auto takes over the WiFi module when running wirelessly on the phone.
In our opinion, the most reasonable option would be to use a GPS module connected to the Raspberry Pi, mainly due to the battery drain caused by the phone's built-in GPS.
Posted: Tue Feb 03, 2026 7:24 am
by Hummer
My thought was just since I already use the gps position from the phone for AA, the companion add could publish the gps coordinates through bluetooth to Hudiy. I was asuming the battery drain would be more or less the same. Only the overhead of sending it via bluetooth from companion app to Hudiy.
I will have a look at using an external gps module connected directly to the rpi.
