Bluetooth Audio
Twardowsky29
Bluetooth Audio
Okay, so I've got another problem, I can't get my RPI to play music through Bluetooth. I'm connecting to my Bluetooth headset in the hudiy menu and it connects, the song is playing on screen the and my phone but there's no sound at all. Any thoughts?
Re: Bluetooth Audio
Hudiy utilizes PipeWire for audio handling. Bluetooth is also managed through PipeWire and its BlueZ plugin.
Additionally, Hudiy includes an Equalizer plugin, which is loaded into PipeWire and exposes its own virtual sink.
Could you let us know what sound card you're using and whether it’s been correctly detected by PipeWire?
You can check that with the following commands:
Also, please make sure the volume on your phone is turned up - many phones default to minimum volume when connecting to a new Bluetooth device.
pactl list cards
pactl list sinksHudiy Team
Twardowsky29
Re: Bluetooth Audio
Okay, so im actually not using any external card. Just the RPI build-in bluetooth module. Is there like a document somewhere that specifies what I need and what I don't need, I feel kinda bad asking questions that seem obvious to you all. I attached the cmd log after those commands.
Maybe you can recommend a card to use for bluetooth and also maybe you can guide me on how to push sound through the audio Jack for future endeavors?
Card #63
Driver: alsa
Owner Module: n/a
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.card.longname = "bcm2835 Headphones"
api.alsa.card.name = "bcm2835 Headphones"
api.alsa.path = "hw:0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.api = "alsa"
device.bus_path = "platform-fe00b840.mailbox"
device.description = "Built-in Audio"
device.enum.api = "udev"
device.form_factor = "internal"
device.icon_name = "audio-card-analog"
device.name = "alsa_card.platform-fe00b840.mailbox"
device.nick = "bcm2835 Headphones"
device.plugged.usec = "4265086"
device.subsystem = "sound"
sysfs.path = "/devices/platform/soc/fe00b840.mailbox/bcm2835-aud io/sound/card0"
media.class = "Audio/Device"
factory.id = "15"
client.id = "43"
object.id = "63"
object.serial = "63"
object.path = "alsa:acp:Headphones"
alsa.card = "0"
alsa.card_name = "bcm2835 Headphones"
alsa.long_card_name = "bcm2835 Headphones"
alsa.mixer_name = "Broadcom Mixer"
alsa.id = "Headphones"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:stereo-fallback: Stereo Output (sinks: 1, sources: 0, pri ority: 5100, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 0, priority: 1, availab le: yes)
Active Profile: output:stereo-fallback
Ports:
analog-output: Analog Output (type: Analog, priority: 9900, late ncy offset: 0 usec, availability unknown)
port.type = "analog"
card.profile.port = "0"
Part of profile(s): output:stereo-fallback
Card #64
Driver: alsa
Owner Module: n/a
api.alsa.card = "1"
api.alsa.card.longname = "vc4-hdmi-0"
api.alsa.card.name = "vc4-hdmi-0"
api.alsa.path = "hw:1"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus_path = "platform-fef00700.hdmi"
device.name = "alsa_card.platform-fef00700.hdmi"
device.nick = "vc4-hdmi-0"
device.plugged.usec = "4274340"
sysfs.path = "/devices/platform/soc/fef00700.hdmi/sound/card1"
factory.id = "15"
client.id = "43"
object.id = "64"
object.serial = "64"
object.path = "alsa:acp:vc4hdmi0"
alsa.card = "1"
alsa.card_name = "vc4-hdmi-0"
alsa.long_card_name = "vc4-hdmi-0"
alsa.driver_name = "vc4"
alsa.id = "vc4hdmi0"
device.string = "1"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sour ces: 0, priority: 5900, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, l atency offset: 0 usec, availability group: Legacy 1, available)
port.type = "hdmi"
port.availability-group = "Legacy 1"
device.icon_name = "video-display"
device.product.name = "HDMI"
iec958.codecs.detected = "[\"PCM\"]"
Part of profile(s): output:hdmi-stereo
Card #65
Driver: alsa
Owner Module: n/a
api.alsa.card = "2"
api.alsa.card.longname = "vc4-hdmi-1"
api.alsa.card.name = "vc4-hdmi-1"
api.alsa.path = "hw:2"
api.dbus.ReserveDevice1 = "Audio2"
device.api = "alsa"
device.bus_path = "platform-fef05700.hdmi"
device.name = "alsa_card.platform-fef05700.hdmi"
device.nick = "vc4-hdmi-1"
device.plugged.usec = "4312880"
sysfs.path = "/devices/platform/soc/fef05700.hdmi/sound/card2"
factory.id = "15"
client.id = "43"
object.id = "65"
object.serial = "65"
object.path = "alsa:acp:vc4hdmi1"
alsa.card = "2"
alsa.card_name = "vc4-hdmi-1"
alsa.long_card_name = "vc4-hdmi-1"
alsa.id = "vc4hdmi1"
device.string = "2"
Profiles:
Active Profile: off
Card #111
Driver: module-bluez5-device.c
Owner Module: n/a
api.bluez5.address = "B4:0B:1D:0A:BC:30"
api.bluez5.class = "0x5a020c"
api.bluez5.connection = "disconnected"
api.bluez5.device = ""
api.bluez5.icon = "phone"
api.bluez5.path = "/org/bluez/hci0/dev_B4_0B_1D_0A_BC_30"
bluez5.auto-connect = "[ hfp_hf hsp_hs a2dp_sink ]"
bluez5.profile = "off"
device.alias = "Antoni's S22"
device.api = "bluez5"
device.bus = "bluetooth"
device.description = "Antoni's S22"
device.form_factor = "phone"
device.icon_name = "audio-card-bluetooth"
device.name = "bluez_card.B4_0B_1D_0A_BC_30"
device.product.id = "0x0100"
device.string = "B4:0B:1D:0A:BC:30"
device.vendor.id = "bluetooth:0075"
factory.id = "15"
client.id = "43"
object.id = "108"
object.serial = "111"
Profiles:
audio-gateway: Audio Gateway (A2DP Source & HSP/HFP AG) (sinks: 0, sources: 0, priority: 256, available: yes)
Active Profile: audio-gateway
pi@raspberrypi:~ $ pactl list sinks
Sink #36
State: SUSPENDED
Description: hudiy_equalizer_sink Sink
Sample Specification: float32le 2ch 48000Hz
Owner Module: 536870916
Volume: front-left: 32768 / 50% / -18.06 dB, front-right: 32768 / 50% / -18.06 dB
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: hudiy_equalizer_sink.monitor
Flags: DECIBEL_VOLUME LATENCY
node.name = "hudiy_equalizer_sink"
device.class = "filter"
audio.channels = "2"
audio.position = "[ FL, FR ]"
node.group = "ladspa-sink-536870916"
pulse.module.id = "536870916"
device.description = "hudiy_equalizer_sink Sink"
node.link-group = "filter-chain-777-12"
node.virtual = "true"
resample.prefill = "true"
resample.disable = "true"
media.name = "hudiy_equalizer_sink Sink input"
stream.is-live = "true"
node.want-driver = "true"
node.autoconnect = "true"
adapt.follower.spa-node = ""
object.register = "false"
factory.id = "7"
client.id = "34"
object.id = "36"
object.serial = "36"
node.driver-id = "85"
Formats:
pcm
Sink #40
State: SUSPENDED
Description: Echo-Cancel Sink
Owner Module: 536870917
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
Monitor Source: echo-cancel-sink.monitor
node.name = "echo-cancel-sink"
pulse.module.id = "536870917"
device.description = "Echo-Cancel Sink"
node.group = "echo-cancel-777-13"
node.link-group = "echo-cancel-777-13"
node.latency = "480/48000"
media.name = "Echo-Cancel Sink"
factory.id = "7"
client.id = "35"
object.id = "40"
object.serial = "40"
Formats:
pcm
Sink #84
State: SUSPENDED
Description: Built-in Audio Stereo
Sample Specification: s16le 2ch 48000Hz
Volume: front-left: 26214 / 40% / -23.88 dB, front-right: 26214 / 40% / -23.88 dB
Base Volume: 56210 / 86% / -4.00 dB
Monitor Source: alsa_output.platform-fe00b840.mailbox.stereo-fallback.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
alsa.card = "0"
alsa.class = "generic"
alsa.device = "0"
alsa.id = "bcm2835 Headphones"
alsa.name = "bcm2835 Headphones"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.sync.id = "00000000:00000000:00000000:00000000"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.position = "FL,FR"
card.profile.device = "1"
device.api = "alsa"
device.class = "sound"
device.id = "63"
device.profile.description = "Stereo"
device.profile.name = "stereo-fallback"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
node.name = "alsa_output.platform-fe00b840.mailbox.stereo-fallback"
node.nick = "bcm2835 Headphones"
object.path = "alsa:acp:Headphones:1:playback"
port.group = "playback"
priority.driver = "1000"
priority.session = "1000"
factory.id = "19"
client.id = "43"
object.id = "84"
object.serial = "84"
api.alsa.card = "0"
sysfs.path = "/devices/platform/soc/fe00b840.mailbox/bcm2835-audio/sound/card0"
device.string = "0"
Ports:
analog-output: Analog Output (type: Analog, priority: 9900, availability unknown)
Active Port: analog-output
Formats:
pcm
Sink #85
State: SUSPENDED
Description: Built-in Audio Digital Stereo (HDMI)
Sample Specification: s32le 2ch 48000Hz
Monitor Source: alsa_output.platform-fef00700.hdmi.hdmi-stereo.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
alsa.card = "1"
alsa.device = "0"
alsa.id = "MAI PCM i2s-hifi-0"
alsa.name = "MAI PCM i2s-hifi-0"
api.alsa.path = "hdmi:1"
api.alsa.pcm.card = "1"
device.api = "alsa"
device.id = "64"
device.profile.description = "Digital Stereo (HDMI)"
device.profile.name = "hdmi-stereo"
device.routes = "1"
iec958.codecs = "[\"PCM\"]"
node.name = "alsa_output.platform-fef00700.hdmi.hdmi-stereo"
node.nick = "MAI PCM i2s-hifi-0"
object.path = "alsa:acp:vc4hdmi0:1:playback"
factory.id = "19"
client.id = "43"
object.id = "85"
object.serial = "85"
api.alsa.card = "1"
device.string = "1"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
Re: Bluetooth Audio
The audio jack on the Raspberry Pi 4B should work out of the box.
In your case, the audio is most likely being routed through HDMI, which is why there's no sound from the audio jack.
To disable HDMI audio, follow the instructions in the Raspberry Pi documentation: https://www.raspberrypi.com/documentati ... hdmi-audio
You’ll need to modify the following line in /boot/firmware/config.txt:
to
Hudiy itself doesn’t have any special audio requirements - it works with whatever is configured at the system level and is compatible with the PipeWire. However, we generally don’t recommend using the audio jack on the Raspberry Pi 4B, as it’s not a true DAC - it’s a basic PWM output with very poor sound quality and slow timing.
No worries at all - we’re here to help!
dtoverlay=vc4-kms-v3dCode: Select all
dtoverlay=vc4-kms-v3d,noaudioNo worries at all - we’re here to help!
Twardowsky29
Re: Bluetooth Audio
Okay, disabled the HDMI, disabled the audio jack, how can I push my audio through bluetooth now?
pactl list cards
Card #63
Driver: alsa
Owner Module: n/a
api.alsa.card = "0"
device.api = "alsa"
device.plugged.usec = "4225892"
factory.id = "15"
client.id = "43"
object.id = "63"
alsa.card = "0"
device.string = "0"
Profiles:
output:stereo-fallback: Stereo Output (sinks: 1, sources: 0, priority: 5100, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 0, priority: 1, available: yes)
Active Profile: off
Ports:
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Card #95
Owner Module: n/a
factory.id = "15"
client.id = "43"
object.id = "92"
object.serial = "95"
Profiles:
Sink #36
State: RUNNING
Volume: front-left: 42598 / 65% / -11.23 dB, front-right: 42598 / 65% / -11.23 dB
node.link-group = "filter-chain-766-12"
factory.id = "7"
client.id = "34"
object.id = "36"
node.driver-id = "30"
Formats:
pcm
Sink #40
State: IDLE
node.group = "echo-cancel-766-13"
node.link-group = "echo-cancel-766-13"
factory.id = "7"
client.id = "35"
object.id = "40"
Formats:
pcm
Re: Bluetooth Audio
Could you describe the configuration you're trying to set up?
If you're planning to receive audio over Bluetooth (e.g. from a phone) and send it out over Bluetooth (e.g. to a Bluetooth speaker) using the same Raspberry Pi, it’s likely that a single Bluetooth module won’t be sufficient.
Bluetooth has very limited bandwidth when it comes to A2DP and can typically only handle one active audio stream at a time.
We're also not sure whether this kind of setup is fully supported by PipeWire and BlueZ - it would likely require additional configuration and some experimentation to see if it’s even possible.
Twardowsky29
Re: Bluetooth Audio
Okay, so I now have the HUDIY RPI that's connected to a screen (Volvo RTI). I also have a bluetooth car adapter that's connected to my radio (for audio and calls). Now what I want to do is connect that radio bluetooth adapter to the HUDIY and then connect my phone to HUDIY for AndroidAuto and all that good stuff.
Hope it makes it clearer.
Re: Bluetooth Audio
This setup looks like some kind of Bluetooth passthrough or Bluetooth audio relay.
As far as we know, a single Bluetooth module won't provide enough bandwidth for this configuration.
You would need two separate Bluetooth adapters (e.g. the built-in module on the Raspberry Pi plus an external USB dongle).
In that case, PipeWire would also need to be correctly configured with HFP Sink/Source and A2DP Sink/Source roles - but unfortunately, we haven’t tested PipeWire in this type of setup, so we can’t confirm if it works reliably.
Even the PipeWire documentation doesn’t mention this use case:
https://docs.pipewire.org/page_config.html
https://docs.pipewire.org/page_man_pipewire_conf_5.html
Probably the simplest and most reliable solution would be to output audio from the Raspberry Pi through a USB sound card, and then connect a Bluetooth audio transmitter (e.g. jack-to-Bluetooth adapter) to that sound card.
You could then pair that adapter with your car audio system.
Re: Bluetooth Audio
I need some advice. Let's say I connect my phone to a hires or LDAC audio receiver via Bluetooth. Can I channel all the audio, phone using this method, can the Android Auto and Carplay still works?
