custom overlays.json example
Posted: Wed Jan 07, 2026 12:23 am
by F4u5t
Could i please see a example of how i should format a custom overlay in the overlays.json, i have found the example html on github, but not sure about the json setup
Re: custom overlays.json example
Posted: Wed Jan 07, 2026 12:33 am
Posted: Wed Jan 07, 2026 7:08 pm
by F4u5t
somehow i missed that one, i copied that exact code, replace my URL, and it works - but i can not drag and drop it, and reading this, it should...
if staticPosition is false, is there anything else that would disable drag and drop on the overlay
staticPosition
Boolean value. A value of true disables Drag & Drop and keystrokes (Left, Right, Up, Down) for positioning the overlay on the screen. A value of false enables them.
Posted: Wed Jan 07, 2026 7:35 pm
From Hudiy side there is only staticPosition parameter that can block drag & drop. Your HTML code may also intercepts the mouse/touch events and block drag & drop.
